Object occlusion issues with camera plugin for ROS
asked 2015-10-23 00:51:39 -0500
I created two simple SDF models to represent a wall section and a door prop (that is, just a board with the picture of a door on it). When I place a "door" in front of a wall and get a camera (via the ROS camera plugin) to record the scene,
image description
The door appears behind the wall in the camera image, even though it is clearly in front of it in the environment view.
image description
However if I use the "Brick Box 3x1x3" from the model library instead of my own wall model, images are generated correctly:
image description
image description
What could be the problem here?
The wall SDF model and texture script are:
yumebros_room_wall_240cm2.sdf
<?xml version='1.0'?>
<sdf version="1.4">
  <model name='yumebros_room_wall_240cm2'>
    <link name='link'>
      <pose>0 0 1.2 0 0 0</pose>
      <collision name='collision'>
            <size>0.2 2.4 2.4</size>
      <visual name='visual'>
          <script>
            <uri>model://yumebros_room_wall_240cm2/materials/scripts</uri>
            <uri>model://yumebros_room_wall_240cm2/materials/textures</uri>
            <name>Yumebros/RoomWallSurface</name>
          </script>
white_paint.material
material Yumebros/RoomWallSurface
  technique
    pass
      texture_unit
        scale 0.125 0.125
And for the door:
yumebros_door_blue.sdf
<sdf version="1.4">
  <model name='yumebros_door_blue'>
    <pose>0 0 1.05 0 0 0</pose>
    <static>1</static>
    <link name='link'>
            <size>0.05 0.92 2.1</size>
          <script>
            <uri>model://yumebros_door_blue/materials/scripts</uri>
            <uri>model://yumebros_door_blue/materials/textures</uri>
            <name>Yumebros/DoorBlue</name>
          </script>
      <self_collide>1</self_collide>
      <gravity>1</gravity>
door_blue.material
material Yumebros/DoorBlue
  technique
    pass
      texture_unit
Im having the same problem with gazebo 5.3 on ubuntu. The background wall appears in front of the object when looking through a gazebo camera object. In my case it is with both textured and untextured walls. The same world setting had no problem with gazebo 5.1.
kke gravatar imagekke ( 2016-07-25 15:01:28 -0500 )edit
Can you try gazebo7?
nkoenig gravatar imagenkoenig ( 2016-07-26 08:51:42 -0500 )edit
im working with ros jade so the recommended version is 5.x. I havent tried updating it.
kke gravatar imagekke ( 2016-07-27 03:44:13 -0500 )edit
answered 2016-08-26 21:55:26 -0500
Turns out this is a known issue in Gazebo. Apparently it is related to specific graphic card driver issues. Currently the only possible solution is to recompile Gazebo with a changed parameter; see Xander Dunn's answer for details.
Asked: 2015-10-23 00:51:39 -0500
Seen: 742 times
Last updated: Aug 26 '16
