sdf robot model slippery, slides no friction
asked 2013-01-30 18:53:18 -0600
Hello I got an issue with a humanoid robot modeled in sdf format. The model itself is fine. However, my problem is the model slips, slides, and can't stay in place as soon as i move a joint (via plugin of window).
The model plug in is not the problem in this case.
I tried inserting the <mu> tags, <surface><contact> <kp> <kd> tags but they don'e work. I suspect I need a separate world plugin but i am not sure about this since the model already has a plugin.
You anyone please advise?
Thank you
Please post your SDF files, and tell us what version of Gazebo you're using.
nkoenig gravatar imagenkoenig ( 2013-01-30 19:06:28 -0600 )edit
i am using Gazebo I am not comfortable posting the whole sdf file. Can i post an sdf file that has only the lower body, that is with links (visual + collision) and joints?
nordegren gravatar imagenordegren ( 2013-02-03 18:47:40 -0600 )edit
thank you hsu i will saw the mu values and they are way higher than what i have, in fact these values are crazy high. i will post some of the code for the links and joints once i figure how to properly use this website.
nordegren gravatar imagenordegren ( 2013-02-06 18:17:39 -0600 )edit
here is a sample of a link
nordegren gravatar imagenordegren ( 2013-02-07 18:49:58 -0600 )edit
<link name="right_foot"> <pose>.030 -.090 .010 0 0 0</pose> <inertial> <mass>1.5</mass> <inertia> <ixx>1.0</ixx><ixy>0.0</ixy><ixz>0.0</ixz><iyy>1.0</iyy><iyz>0.0</iyz><izz>1.0</izz> </inertia> </inertial> <collision name="collision"> <geometry> <box><size>.300 .120 .020</size></box> <!-- <mesh><uri>model://</uri></mesh> --> </geometry> <surface> <friction> <ode><mu>0.3</mu></ode
nordegren gravatar imagenordegren ( 2013-02-07 18:52:09 -0600 )edit
nordegren gravatar imagenordegren ( 2013-02-07 18:52:10 -0600 )edit
nordegren gravatar imagenordegren ( 2013-02-07 18:52:11 -0600 )edit
It will be hard to debug your problem without a complete SDF file. We can take this offline so that you don't have to post a complete SDF. Please contact me using nate@osrfoundation.org
nkoenig gravatar imagenkoenig ( 2013-03-07 22:55:20 -0600 )edit
answered 2013-02-05 13:57:23 -0600
Ideally, it will be sufficient if you can post a simple (stripped down) version of the model that others can use to reproduces the problem.
Here is an example of usage of friction (not a terribly good one because we are using a very large mu as the place holder until we get better contact properties). But in general, contact friction should have an effect in simulation.
It's possible the problem might be more than just contact; for example you can isolate the issue by turning off controllers/plugins to see if friction behavior changes.
answered 2013-02-07 19:01:42 -0600
this is a sample of the robot The entire robot still slips regardless of mu values or mass values
<!-- left foot -->
  <link name="left_foot">
    <pose>.030 .090 .010 0 0 0</pose>
      <mass>1.5</mass>
      <surface>
        <friction>
          <ode><mu>100000.0</mu><mu2>100000.0</mu2></ode>
        </friction>
      </surface>
you can update your original question with the model
hsu gravatar imagehsu ( 2013-02-07 19:35:25 -0600 )edit
hi hsu could you please clarify the request. I don't quite understand (sorry).
nordegren gravatar imagenordegren ( 2013-02-12 18:10:34 -0600 )edit
answered 2013-02-12 05:01:19 -0600
updated 2013-02-16 14:29:11 -0600
@nordegren, if you think that problem is the controller, could you post your code? I am not sure if animations take into account the physics engine.
@nordegren I am new in gazebo, but here [http://gazebosim.org/wiki/Tutorials/1...] says that animation engine doesn't take into account physics engine. So I don't know if your animation plugin do the black magic and your model slips.
@hsu, the animation classes take into account the physics engine?
Daniel Vaz gravatar imageDaniel Vaz ( 2013-02-13 04:07:37 -0600 )edit
answered 2018-01-05 12:16:30 -0600
has anyone got the answer. I am also facing this problem. thanks in advance.
Given how old the original question is, I'd suggest asking a new question. Including a full URDF/SDF in your question will increase the odds that somebody can help you!
josephcoombe gravatar imagejosephcoombe ( 2018-01-08 15:50:43 -0600 )edit
answered 2013-02-11 22:45:07 -0600
hello hsu I also already tried the <min_depth> tags and still did not work. I exhausted every single possibility and the robot still slips.
robot does not slip when no plugin is loaded to it. however, in case of my humanoid, the robot collapses on its own weight because there is nothing controlling the joints.
my big problem is that when i use a plugin to control the robot joints (i.e. program some robot motions) the robot beings to slip as soon as a joint moves.
I don't know what else to do. This is the reason why i started this thread.
another possibility is controller tuning. Can you say a little more about the types of controller you are using?
hsu gravatar imagehsu ( 2013-02-14 20:39:36 -0600 )edit
answered 2013-02-14 19:02:02 -0600
class Motion : public ModelPlugin { public: void Load(physics::ModelPtr model, sdf::ElementPtr /*sdf*/) { std::map<std::string, common::numericanimationptr=""> motion;
  motion["thor-op::l_hip_pitch"].reset(new common::NumericAnimation("motion", 4.5, true));
  so on and so on for every other joint
  common::NumericKeyFrame *key = motion["thor-op::l_hip_pitch"]->CreateKeyFrame(0.0);
  key->SetValue(0.0);
  key = motion["thor-op::l_hip_pitch"]->CreateKeyFrame(.75);
  key->SetValue(-1.57);
  so on and so on for every other joint, for every .75 seconds until 4.5 seconds
model->SetJointAnimation(motion); } }; GZREGISTERMODELPLUGIN(Motion) }
So what happens is as soon as the robot moves it begins to slip and slide. however, when no plugin is loaded the model stays in place but it collapses under its own weight.
@nordegren I am new in gazebo, but here [http://gazebosim.org/wiki/Tutorials/1.3/intermediate/animate_pose] says that animation engine doesn't take into account physics engine. So I don't know if your animation plugin do the black magic and your model slips.
Daniel Vaz gravatar imageDaniel Vaz ( 2013-02-15 03:27:11 -0600 )edit
answered 2013-02-18 22:16:42 -0600
does this mean that when writing an animation plugin you must "manually" implement the physics engine? if so how? there's nothing on physics engine when using common::NumericAnimation() classes
I really don't know. But there is no chance to implement the physics engine. I think that the best approach is try to create a PID controller that applies force to robot joints. I am new in gazebo. Maybe @nkoenig or @hsu can help you.
Daniel Vaz gravatar imageDaniel Vaz ( 2013-02-19 06:43:33 -0600 )edit
answered 2013-02-11 18:56:12 -0600
thank you hsu for your answer.
i already tried this method way before i started this thread. the problem is that as soon as i load a plugin to the model to control the joints position (common::NumericAnimation, SetValue(double position)) the model begins slipping regardless how heavy or how high the mu's are set.
Of course if i do not load a controller to the model then the robot collapses on its own weight (without slipping).
answered 2013-02-07 21:17:35 -0600
hsu gravatar image
I created a world with two copies of your link, one with 0 friction one with high friction:
<?xml version="1.0" ?>
<sdf version="1.3">
  <world name="default">
    <physics type="ode">
      <gravity>0.1 0 -9.81</gravity>
    </physics>
      <uri>model://sun</uri>
    <!-- A ground plane -->
    <model name="right_foot">
      <pose>0 1 .005 0 0 0</pose>
          <mass>1.5</mass>
          <surface>
            <friction>
              <ode><mu>0.0</mu><mu2>0.0</mu2></ode>
            </friction>
          </surface>
    <model name="left_foot">
      <pose>0 0 .005 0 0 0</pose>
          <mass>1.5</mass>
          <surface>
            <friction>
              <!--<ode><mu>100000.0</mu><mu2>100000.0</mu2></ode>-->
            </friction>
          </surface>
  </world>
If you save the above world as test.world, then start gazebo by calling
gazebo test.world
One of the boxes slides while the other stays stationary under a lateral gravity field. So it appears to be working correctly for me.
answered 2013-02-14 18:56:28 -0600
I have posted a sample code of the controller 2 days ago. I don't know why the code is not posted. I will repost again
2 followers
Asked: 2013-01-30 18:53:18 -0600
Seen: 14,266 times
Last updated: Jan 05 '18
