Building hector_quadrotor failed
asked 2013-02-03 18:13:12 -0500
updated 2013-02-04 12:27:37 -0500
Hi, I have installed ROS and Gazebo and I tried to build this project:
http://www.ros.org/wiki/hector_quadrotor/Tutorials/Quadrotor%20indoor%20SLAM%20demo
After I executing
rosmake hector_quadrotor_demo
All things work well unless I meet these errors:
mkdir -p bin
cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=/opt/ros/groovy/share/ros/core/rosbuild/rostoolchain.cmake ..
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Found PythonInterp: /usr/bin/python (found version "2.7.3")
[rosbuild] Building package hector_quadrotor_gazebo_plugins
Failed to invoke /opt/ros/groovy/bin/rospack deps-manifests hector_quadrotor_gazebo_plugins
[rospack] Error: package/stack 'hector_quadrotor_gazebo_plugins' depends on non-existent package 'hector_gazebo_plugins' and rosdep claims that it is not a system dependency. Check the ROS_PACKAGE_PATH or try calling 'rosdep update'
CMake Error at /opt/ros/groovy/share/ros/core/rosbuild/public.cmake:129 (message):
Failed to invoke rospack to get compile flags for package
'hector_quadrotor_gazebo_plugins'.  Look above for errors from rospack
itself.  Aborting.  Please fix the broken dependency!
Call Stack (most recent call first):
/opt/ros/groovy/share/ros/core/rosbuild/public.cmake:203
(rosbuild_invoke_rospack)
CMakeLists.txt:12 (rosbuild_init)
-- Configuring incomplete, errors occurred!
[ rosmake ] Output from build of package hector_quadrotor_gazebo_plugins written to:
[ rosmake ]
/home/hongbo-miao/.ros/rosmake/rosmake_output-20130203-101443/hector_quadrotor_gazebo_plugins/build_output.log
[rosmake-1] Finished <<< hector_quadrotor_gazebo_plugins [FAIL] [ 2.95 seconds ]
[ rosmake ] Halting due to failure in package hector_quadrotor_gazebo_plugins.
[ rosmake ] Waiting for other threads to complete.
[rosmake-0] Finished <<< hector_uav_msgs [PASS] [ 112.02 seconds ]
[ rosmake ] Results:
[ rosmake ] Built 69 packages with 1 failures.
[ rosmake ] Summary output to directory
[ rosmake ] /home/hongbo-miao/.ros/rosmake/rosmake_output-20130203-101443
If I continue executing
roslaunch hector_quadrotor_demo indoor_slam_gazebo.launch
I will get this error:
cannot locate [indoor_slam_gazebo.launch] in package [hector_quadrotor_demo]
Can somebody help me? Thank you very much.
Which version of ROS have you installed? Have you done initialize rosdep?
Alex Buyval gravatar imageAlex Buyval ( 2013-02-04 00:57:36 -0500 )edit
answered 2013-02-04 10:27:10 -0500
updated 2013-02-04 10:44:09 -0500
Hi, @Alex Buyval, I have got the answer from ROS Q&A Forum. Anyway, thank you for your quick response.
The respondent on ROS Q&A Forum said that information about required stacks was indeed incomplete in the tutorials. And he has added the missing stacks in the prerequisites section.
Hope this can help guys who meet the same problem. For more details, please see:
http://answers.ros.org/question/54111/building-hector_quadrotor-failed/
Asked: 2013-02-03 18:13:12 -0500
Seen: 390 times
Last updated: Feb 04 '13
