Using ROS without gazebo_ros_pkgs ?
asked 2015-11-12 08:50:34 -0600
debz gravatar image
I made a project using Gazebo and plugins to simulate a Robot. ROS is now not even installed on my computer. I wonder if I can use the roscpp librairy to integrate ROS in my project, without using the gazebo_ros_pkgs. The reason why I want to do like this is that I would like to compare my own IK algorithm to common ones available with ROS, and therefore integrate ROS in my Gazebo model_plugin.
As you might guess, I don't really know the ROS environnement. Just tell me if my question doesn't make sens!
Best.
answered 2015-11-12 09:48:30 -0600
nkoenig gravatar image
You don't need to use gazebo_ ros_pkgs in order to use ROS with Gazebo. In fact, gazebo_ros_pkgs consists mostly of Gazebo plugins that have some component of ROS.
I'd recommend looking at the source code of gazebo_ros_pkgs for tips and ideas on integrating ROS with your own Gazebo plugins. Here is a good example
Asked: 2015-11-12 08:50:34 -0600
Seen: 76 times
Last updated: Nov 12 '15
