Get data from sensor to control a robot
asked 2015-12-09 19:31:29 -0600
lemour_a gravatar image
I'm totally new to Gazebo and I'm currently trying to exploit the data from the laser sensor I put on a robot. I noticed this post : http://answers.gazebosim.org/question..., so I tried to read the laser data from the corresponding topic which is "/gazebo/default/roc_robot/hokuyo/link/laser/scan" in my case.
This is my model plugin (used by the robot model) :
namespace gazebo
  class RocPlugin : public ModelPlugin
  private:
    physics::ModelPtr           model;
    transport::SubscriberPtr    sptr;
  public:
    void Load(physics::ModelPtr _parent, sdf::ElementPtr /*_sdf*/)
      std::string             topicName = "/gazebo/default/roc_robot/hokuyo/link/laser/scan";
      transport::NodePtr      node(new transport::Node());
      model = _parent;
      node->Init();
      node = node->Subscribe(topicName, &RocPlugin::ReadLaserData, this);
   void ReadLaserData(ConstRaySensorPtr &_msg)
      std::cout << _msg->range_max() << std::endl;
    GZ_REGISTER_MODEL_PLUGIN(RocPlugin)
And I got this error :
gzserver: /usr/include/boost/smart_ptr/shared_ptr.hpp:687: typename boost::detail::sp_member_access<t>::type boost::shared_ptr<t>::operator->() const [with T = const gazebo::msgs::RaySensor; typename boost::detail::sp_member_access<t>::type = const gazebo::msgs::RaySensor*]: Assertion `px != 0' failed.
Since I aim to move the robot according to the data produced by the laser I haven't tried to write a plugin for the laser because even if I manage to read data from a sensor plugin I need those in my model plugin to control my robot.
Can you give me a tip for doing it ? ( Thank you ! )
any updates here? i have the same issue. sometimes even i get an error that gazebo is not able to read the Message. Using gazeboJS i get empty values.
zesaro gravatar imagezesaro ( 2018-01-05 23:15:49 -0600 )edit
