Error Installing Gazebo from Source in a Catkin ws on Linux: Cannot find -lccd
asked 2016-01-18 11:13:20 -0600
Hello everyone,
I'm having issues installing gazebo from source. I'm following the tutorial on this page:
http://gazebosim.org/tutorials?tut=in...
With the catkin workspace guidelines: I've cloned all the necessary packages, checked out the branches I need (gazebo 6, sdf3) and added the package.xml files.
All looked well, I initialized catkin and tried running the catkin build block provided by the page. As "catkin build" wasn't recognized I used "catkin_make_isolated" instead. Dart, Bullet and SDF go through without any issues, but as Gazebo is being built I get the following error:
[ 50%] Built target gazebo_gui_model
/usr/bin/ld: cannot find -lccd
collect2: error: ld returned 1 exit status
make[2]: * [gazebo/physics/libgazebo_physics.so.6.5.1] Fehler 1
make[1]: * [gazebo/physics/CMakeFiles/gazebo_physics.dir/all] Fehler 2
Has anyone got an Idea where this issue can come from?
Kind regards, Alex
answered 2016-01-19 04:42:17 -0600
AndreiHaidu gravatar image
Hi there,
starting gazebo6: "Support for DART version 5.0 is integrated into the default branch.", so Optional Physics Engines: Dart Support is no longer "Optional"?.
Try running these in your terminal:
# Only needed on Trusty. Ubuntu packages since Utopic.
sudo apt-add-repository ppa:libccd-debs
sudo apt-add-repository ppa:fcl-debs
# Main repository
sudo apt-add-repository ppa:dartsim
sudo apt-get update
sudo apt-get install libdart-core5-dev
Source: Installation tutorial.
Cheers, Andrei
Hi Andrei, thanks for the answer! Unfortunately I can't easily install ppa repositories due to restricted rights. The thing that confuses me though is that libccd is already available in gazebo 6.... I'm currently trying to figure out why it doesn't work regardless. Any ideas? Cheers, Alex
lesi gravatar imagelesi ( 2016-02-05 03:32:09 -0600 )edit
Asked: 2016-01-18 11:13:20 -0600
Seen: 581 times
Last updated: Jan 19 '16
