How to stop a robot from going out of its joint limits?
asked 2016-01-29 17:31:37 -0600
balakumar-s gravatar image
I have a KUKA LBR model and I have set its joint limits but the problem is these joint limits affect only the ros_controller and when I just spawn the robot, it goes beyond its limit and I am not able to get it back to an allowed angle.
answered 2016-01-31 11:34:09 -0600
dcconner gravatar image
http://wiki.ros.org/urdf/XML/joint You need to set the hard limits in the urdf file, and make sure the joint is not set to continuous.
It sounds like you only have "safety limits" set, or the limits for the ros_controller set and not the physical limits.
See this example from https://bitbucket.org/osrf/drcsim/src...
Note the difference between lower/upper hard limits of revolute joint, and the soft_*_limits.
 <joint name="back_bkx" type="revolute">
<origin rpy="0 0 0" xyz="0 0 0.05"/>
<axis xyz="1 0 0"/>
<parent link="mtorso"/>
<child link="utorso"/>
<dynamics damping="0.1" friction="0"/>
<limit effort="300" lower="-0.523599" upper="0.523599" velocity="12"/>
<safety_controller k_position="100" k_velocity="100" soft_lower_limit="-10.5236" soft_upper_limit="10.5236"/>
Asked: 2016-01-29 17:31:37 -0600
Seen: 1,549 times
Last updated: Jan 31 '16
