Opening a text file through a plugin
asked 2016-02-17 04:05:17 -0600
pap-x gravatar image
updated 2016-02-17 04:08:42 -0600
I'm trying to open a text file through a plugin to get timestamps and positions for keyframes of a model animation. I'm opening the file using ifstream(). Unfortunately no matter where I place the text file it won't be opened by the plugin. What can I do?
Have you tried using the file's full path? Does that work?
chapulina gravatar imagechapulina ( 2016-02-17 09:12:33 -0600 )edit
Yeap! Full path did work, thank you! (Had tried that already but I was missing something probably)
pap-x gravatar imagepap-x ( 2016-02-18 01:14:56 -0600 )edit
2
answered 2016-02-17 09:25:35 -0600
debz gravatar image
I also use an external file for my current project. Here is the code:
std::ifstream f(path.c_str(), std::ios::in);
Here, path is a std::string object. Be ware that the path is relative to the folder where you run gazebo, NOT relative to the folder of your plugin. If you know exactly where you run gazebo, then adapt your path or you can use an absolute path, as chapulina said.
Asked: 2016-02-17 04:05:17 -0600
Seen: 141 times
Last updated: Feb 17 '16
