How can I use the deprecated function SetAngle?
asked 2016-02-29 06:09:30 -0600
gabri89 gravatar image
Hi everybody, In my plugin I want to set the angle of a revolute joint according with a particular dynamic. To do this I used the function
void gazebo::physics::Joint::SetAngle ( unsigned int  _index, math::Angle  _angle)
This function in declared as GAZEBO_DEPRECATED(version). When I try to compile the code, I have this return :
warning: 'void gazebo::physics::Joint::SetAngle(unsigned int, gazebo::math::Angle)' is deprecated (declared at /usr/include/gazebo-5.2/gazebo/physics/joint.hh:396 [-Wdeprecated-declaretions].
I'm not able to understand why I can't use this function. Is there a method that enables the user to use this type of function?
I tried to add this piece of code :
 #if defined(__GNUC__)
 #define GAZEBO_DEPRECATED(version) __attribute__((deprecated))
 #define GAZEBO_FORCEINLINE __attribute__((always_inline))
 #elif defined(_WIN32)
 #define GAZEBO_FORCEINLINE __forceinline
 #else
 #define GAZEBO_DEPRECATED(version) ()
 #endif
But appears an error like:
may not appear in macro parameter list
Otherwise, is there other functions that can make the same thing of SetAngle?
Thank you, bye!
2
answered 2016-02-29 06:53:53 -0600
Brosseau.F gravatar image
I don't know how to use a deprecated function (maybe it depends on the gazebo version you use).
The new function should be SetPosition .
https://osrf-distributions.s3.amazona...
Thank you, the error disappears! I hope that the joint will behave as I want.
gabri89 gravatar imagegabri89 ( 2016-02-29 07:10:24 -0600 )edit
Asked: 2016-02-29 06:09:30 -0600
Seen: 1,595 times
Last updated: Feb 29 '16
