Use of GetLinkForce or GetLinkTorque
asked 2016-03-16 12:14:32 -0600
gabri89 gravatar image
In my gazebo plugin, I have to use the function
virtual math::Vector3 gazebo::physics::Joint::GetLinkForce ( unsigned int   _index) const pure virtual
or
virtual math::Vector3 gazebo::physics::Joint::GetLinkTorque ( unsigned int  _index) const pure virtual
These functions should return the force applied at the centre of mass of a link; the problem is that this functions are pure virtual, so I must define them. I could use the ODEJoint class (that inherits from Joint class): this owns the above functions, but only virtual.
I don't understand how to use the ODEJoint class, nay how to include this class in my plugin.
Can I use this functions without having ODEJoint?
Thank you!
answered 2016-03-23 03:48:39 -0600
Hi I solved the proble adding
joint1->SetProvideFeedback(1);
command. So I can use GetLinkForce without problem.
answered 2016-03-16 12:24:16 -0600
nkoenig gravatar image
Those functions get implemented by a specific physics engine, such as ODE or Bullet or Simbody. You can call a pure virtual function, and the correct implementation will be used automatically.
You should not try to implement that function, unless you are trying to implement a new physics engine.
Maybe you should describe what you are trying to do.
Hi, I would like to obtain the force applied on the link at every gazebo step. So, as usual I get the pointer to the joint in the Load function: joint=this->model->GetJoint("joint_name"); Then in the OnUpdate function (called in the Load) I try to obtain the force: force=joint->GetLinkForce(index); (I defined force as a class variable math::Vector3). This causes segmentation fault. Can my problem be caused by an error on the pointer? I thought that it was caused by the GetLinkForce function.
gabri89 gravatar imagegabri89 ( 2016-03-16 13:27:28 -0600 )edit
You should generate a backtrace using gdb to see where the segmentation fault is occurring. You could have a bad pointer, but it's hard to say without more information.
nkoenig gravatar imagenkoenig ( 2016-03-16 13:32:20 -0600 )edit
answered 2016-03-16 12:27:46 -0600
chapulina gravatar image
You're not the one who must define it, each of the 4 physics engines supported by Gazebo will have its implementation.
Gazebo's API is organized in a way that you can call the base class functions, and under the hood, the function for the current physics engine will be called for you. This is made so you can switch physics engines without changing your code.
So if you're using ODE as the physics engine and call Joint::GetLinkForce, ODEJoint::GetLinkForce will actually be called. The same is valid for the other physics engines.
See this plugin for example. It calls SetForce, which is also pure virtual.
Asked: 2016-03-16 12:14:32 -0600
Seen: 459 times
Last updated: Mar 23 '16
