What's the proper way to use gzerr?
asked 2016-04-13 21:39:00 -0600
pcdangio gravatar image
I'm trying to use gzerr to output error messages to the console in which gazebo is running from. If I put the following code in my model plugin's load method, the gzerr text never shows in the console.
gzerr << "this message never gets displayed\n";
std::cout << "this message gets displayed just fine" << std::endl;
I'm starting gazebo using the "gazebo" command, and I have verified with an std::cout that the plugin's load method is getting called. I've also made sure that gazebo/common/Console.h is included. I've also tried using sdferr the same way as gzerr, and sdferr works exactly as expected.
What am I doing wrong?
answered 2016-04-13 22:33:29 -0600
chapulina gravatar image
Run Gazebo in verbose mode:
gazebo --verbose
Thanks! Interesting that by default error messages won't show up. What's the proper way then, to notify the user of an error if not running in verbose mode?
pcdangio gravatar imagepcdangio ( 2016-04-14 09:48:05 -0600 )edit
It depends on the "user". If it's someone who will be using the command line, you'd use the verbose mode. If it's a graphical interface user, you could make a GUI plugin which prints messages to the screen.
chapulina gravatar imagechapulina ( 2016-04-14 11:52:04 -0600 )edit
Asked: 2016-04-13 21:39:00 -0600
Seen: 743 times
Last updated: Apr 13 '16
