How to project from world to image pixel coordinates in a CameraSensor plugin
asked 2016-04-22 16:56:32 -0600
Andrew Symington gravatar image
I have written a gazebo CameraSensor plugin to draw sparse features from a map, based on the frustrum of the camera. I can get the frustrum information (HFOV, VFOV, near and far clip) from sensors::CameraSensor::Camera(), and I can work out the camera extrinsics from the link and sensor pose. What I can't seem to work out is how is perform an inverse pinhole projection from world coordinates (X,Y,Z) to image plane coordinates (U,V). Is this possible with the Gazebo API or do I need to use the image_geometry package in ROS to achieve this?
Any ideas?
asdfjkl gravatar imageasdfjkl ( 2016-05-26 19:13:36 -0600 )edit
answered 2016-05-27 10:35:35 -0600
nkoenig gravatar image
Gazebo currently doesn't provided a built-in function to map world-coordinate to image plane coordinate. You can use the ROS image_geometry package, opencv, write your own, or use some other software for this.
The rendering::Camera class does provide a function called CameraToViewportRay which gets a world space ray as cast from the camera through its viewport. This may be of use to you.
2 followers
Asked: 2016-04-22 16:56:32 -0600
Seen: 817 times
Last updated: May 27 '16
