Invoking "make -j2 -l2" failed
asked 2016-04-25 09:25:43 -0500
Mrmrzamany gravatar image
updated 2016-04-26 19:17:37 -0500
scpeters gravatar image
Hi, i followed exactly the instructions here http://erlerobotics.com/docs/Simulati... , everything went find except the very last command :::
Then compile everything together:
cd ~/simulation/ros_catkin_ws
source devel/setup.bash catkin_make
Error in the terminal :
[ 98%] Building CXX object ardupilot_sitl_gazebo_plugin/ardupilot_sitl_gazebo_plugin/CMakeFiles/ardupilot_sitl_gazebo_plugin.dir/src/SocketAPM.cpp.o
Linking CXX shared library /home/omaralhebsi/simulation/ros_catkin_ws/devel/lib/libardupilot_sitl_gazebo_plugin.so
[ 98%] Built target ardupilot_sitl_gazebo_plugin
make: * [all] Error 2 Invoking "make -j2 -l2" failed
What do i have to do ?? , plz help its only one step and then i can start working on Gazebo . I guess the problem is with catkin_make
i ran the code again and this is what i received :
[100%] Built target sitl_test_node /home/simulation/ros_catkin_ws/src/gazebo_cpp_examples/erle-copter_pattern_follower/src/image_subscriber.cpp:5:25:
fatal error: aruco/aruco.h: No such file or directory #include <aruco aruco.h=""> ^ compilation terminated.
make[2]: * [gazebo_cpp_examples/erle-copter_pattern_follower/CMakeFiles/ros_erle_pattern_follower.dir/src/image_subscriber.cpp.o] Error 1 make[1]: [gazebo_cpp_examples/erle-copter_pattern_follower/CMakeFiles/ros_erle_pattern_follower.dir/all] Error 2 make: ** [all] Error 2 Invoking "make -j2 -l2" failed
The link you gave is broken and I think you forgot to add some information in the end.
chapulina gravatar imagechapulina ( 2016-04-25 11:42:10 -0500 )edit
check down
Mrmrzamany gravatar imageMrmrzamany ( 2016-04-26 03:17:03 -0500 )edit
check down plz @chapulina
Mrmrzamany gravatar imageMrmrzamany ( 2016-04-26 08:35:53 -0500 )edit
fatal error: aruco/aruco.h: No such file or directory that seems to be the error
scpeters gravatar imagescpeters ( 2016-04-26 19:18:35 -0500 )edit
answered 2016-04-26 03:16:45 -0500
http://erlerobotics.com/docs/Simulati... this is the link
[100%] Built target sitl_test_node /home/simulation/ros_catkin_ws/src/gazebo_cpp_examples/erle-copter_pattern_follower/src/image_subscriber.cpp:5:25: fatal error: aruco/aruco.h: No such file or directory #include <aruco aruco.h=""> ^ compilation terminated. make[2]: * [gazebo_cpp_examples/erle-copter_pattern_follower/CMakeFiles/ros_erle_pattern_follower.dir/src/image_subscriber.cpp.o] Error 1 make[1]: [gazebo_cpp_examples/erle-copter_pattern_follower/CMakeFiles/ros_erle_pattern_follower.dir/all] Error 2 make: ** [all] Error 2 Invoking "make -j2 -l2" failed
Asked: 2016-04-25 09:24:48 -0500
Seen: 1,119 times
Last updated: Apr 26 '16
