Missing documentation for sdf actor
asked 2016-05-23 10:40:56 -0600
randaz gravatar image
http://sdformat.org/spec?ver=1.6&elem... does not explain how to use the tags and and what the two .dae files (moonwalk.dae and walk.dae) mentioned in the example on the right should contain(*). Additionally, the example does not work on gazebo7: it simply does not load the model, without displaying any warning/error message even in verbose mode.
(*) e.g. if i want a simple body (sphere) that moves around a fixed trajectory, should <skin> contain the sphere model? And <animation> ?.
answered 2016-05-23 10:56:31 -0600
chapulina gravatar image
I ticketed an issue asking for more detailed documentation on the Actors feature.
Meanwhile, if you want to implement a sphere moving in a fixed trajectory, you might want to check out the tutorial on animations.
Asked: 2016-05-23 10:40:56 -0600
Seen: 389 times
Last updated: May 23 '16
