How to disable gravity only for a specific model in Gazebo?
asked 2016-05-26 22:16:18 -0500
webvenky gravatar image
updated 2016-05-26 22:39:32 -0500
A similar question has been answered. http://answers.ros.org/question/65991...
However, this only works for the .sdf model files. It does not work for urdf. Kindly help.
<link name="base_link" gravity="0 0 0">
    <gravity>0</gravity>
  <joint name="base_joint" type="fixed">
    <parent link="base_link" />
    <child link="body_link" />
  <link name="body_link">
      <mass value="0.1" />
      <origin xyz="0 0 0" />
      <inertia ixx="1" ixy="0" ixz="0" iyy="1" iyz="0" izz="1" />
    <visual name="base_visual">
      <geometry name="pioneer_geom">
        <mesh filename="package://rotors_description/meshes/simple_airplane1.dae" />
    <collision>
answered 2016-05-26 22:44:42 -0500
chapulina gravatar image
It looks like your file is in the URDF format (you use origin instead of pose for example).
<gravity> within a link is specified in SDF, but not in URDF. Luckily, the conversion from URDF to SDF is possible. In order to use SDF tags within your URDF link, use the <gazebo> tag, as explained in this tutorial. It should look something like this:
Thanks a lot! It works. :-)
webvenky gravatar imagewebvenky ( 2016-05-26 22:58:13 -0500 )edit
Does it remain static in the world even if something collide with it? I was looking for something more like the <static> tag.
hbaqueiro gravatar imagehbaqueiro ( 2018-11-05 09:41:14 -0500 )edit
No, it will not remain static, it will just not be affected by gravity. There's no way to set only one link to be static, that tag works only on the model level. You can however make a model static and connect it to a non-static model with a joint.
chapulina gravatar imagechapulina ( 2018-11-05 12:12:57 -0500 )edit
2 followers
Asked: 2016-05-26 22:16:18 -0500
Seen: 6,355 times
Last updated: May 26 '16
