How to move a object on Gazebo
asked 2016-06-01 00:58:17 -0500
kmyang85@gmail.com gravatar image
HI! All
I want to make a moving object on ROS Indigo so I fallow this tutorial http://www.generationrobots.com/en/co...
In this tutorial, It is implemented on Hydro.
This tutorial can work on Hydro but it doesn't work on Indigo.
I already fixed this sentence
<joint name="${lr}_wheel_hinge"/> to
<joint name="${lr}_wheel_hinge"> <hardwareinterface>EffortJointInterface</hardwareinterface> </joint> in macros.xacro file
So that I can fix all error when I run Gazebo with this world file.
However, my model just turn wheels not move position on Gazebo when I send topic using turtlebot teleop.
I guess this plugin "libgazebo_ros_diff_drive.so" may be changed but I'm not sure.
Please answer if you know how to fix it or if you know some tutorial codes that I can use.
Thank you.
answered 2016-06-02 11:12:31 -0500
chapulina gravatar image
This website has a lot of resources for learning hot to use the Turtlebot in simulation:
http://learn.turtlebot.com/
This video also looks interesting:
https://www.youtube.com/watch?v=9U6GD...
They both use ROS Indigo
Asked: 2016-06-01 00:58:17 -0500
Seen: 3,891 times
Last updated: Jun 02 '16
