Native spherical (WGS84) coordinates?
asked 2016-06-07 09:45:56 -0600
laughlin gravatar image
Hello all,
I'm looking to build a simulation where I can accurately bookkeep my robots position in geodetic coordinates (WGS84 datum).
Unfortunately the ROS+Gazebo+Hector GPS plugin route isn't likely to work, exactly because I'm trying to simulate vehicles at high latitude (near the poles), and traveling large distances O(10 km).
Is it possible for Gazebo to run a simulation natively in spherical coordinates? I haven't been able to find any resources to date on this.
If not, have any others found themselves in a similar situation? Outside of writing a dynamical model in MATLAB or similar, have others found an acceptable solution?
answered 2016-06-07 09:58:03 -0600
nkoenig gravatar image
Thanks @nkoenig. So if I understand correctly, underlying cord sys is still XYZ, but Spherical Coord. class implements proper WGS84<-->local XYZ (via intermediate ECEF frame), with local XYZ origin at the lat/long specified in world file (as defined here: http://sdformat.org/spec?ver=1.6&elem=world#world_spherical_coordinates). Local XYZ is in an ENU orientation. Does this sound correct?
laughlin gravatar imagelaughlin ( 2016-06-07 13:52:34 -0600 )edit
That is correct.
nkoenig gravatar imagenkoenig ( 2016-06-07 17:05:59 -0600 )edit
Thank you.
laughlin gravatar imagelaughlin ( 2016-06-08 09:03:41 -0600 )edit
Asked: 2016-06-07 09:40:37 -0600
Seen: 1,457 times
Last updated: Jun 07 '16
