What are the things to be included in the CMakeLists.txt file for using gazebo plugins with ROS?
asked 2016-06-14 15:04:52 -0600
vatsal gravatar image
I want a plugin for using camera in gazebo with ros integration. I already have the .cpp file for the plugin but dont know what all is to be included in the CMakeLists.txt file. Please Help!
answered 2016-06-23 14:23:34 -0600
m4k gravatar image
updated 2016-06-23 14:31:36 -0600
if you are "just" looking for the CMakeList.txt see below. It also depends on your plugin what 'includes/packages' are required. In addition you need your program to be in a catkin / ros package. (see the tutorial link below)
cmake_minimum_required(VERSION 2.8.3)
project(gazebo_tutorials)
# Load catkin and all dependencies required for this package
find_package(catkin REQUIRED COMPONENTS
  roscpp
  gazebo_ros
# Depend on system install of Gazebo
find_package(gazebo REQUIRED)
link_directories(${GAZEBO_LIBRARY_DIRS})
include_directories(${Boost_INCLUDE_DIR} ${catkin_INCLUDE_DIRS} ${GAZEBO_INCLUDE_DIRS})
add_library(${PROJECT_NAME} src/simple_world_plugin.cpp)
target_link_libraries(${PROJECT_NAME} ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
catkin_package(
  DEPENDS
    roscpp
    gazebo_ros
As mentioned previously you should go through the tutorial. This is from where I got the above code: http://gazebosim.org/tutorials?tut=ro...
To understand the CMakeList file, read here: http://wiki.ros.org/catkin/CMakeLists...
answered 2016-06-14 17:50:30 -0600
The tutorial on plugins demonstrates a simple CmakeLists.txt for a gazebo plugin
http://gazebosim.org/tutorials?tut=pl...
If you want to use ros as well you will some of the cmake from that as well. There are some examples, such as the hector and turtlbot gazebo plugins which you can look at as well.
Asked: 2016-06-14 15:04:52 -0600
Seen: 2,617 times
Last updated: Jun 23 '16
