How to set path between 2 points and make robot to take sensor data while moving on it ?
asked 2013-02-13 20:22:10 -0500
amit gravatar image
I have created a basic world model with cylinders and boxes as obstacles. I am using Pioneer robot. I want to make a path between a start point and an end point (random points in the world) and want the robot to move on the path and get the sensor data. I was thinking to use Sonar data but I guess laser or IR would work too. I have no clue how to proceed and what to do.
I am trying implement Kalman Filter for Robot Localization. For that I need to get the data from the world, then add noise to it and then use Kalman filter to estimate the actual data from the noisy data. I am stuck at the very first step.
What shall I do to proceed ? Do I need to install ROS ? I have installed only Gazebo on my Ubuntu. Is that good enough ?
I am new to Gazebo and perhaps the only one to use Gazebo in my university. Please pardon me if my questions are very trivial and stupid.
2
answered 2013-02-14 15:09:40 -0500
updated 2013-02-14 15:11:46 -0500
Well, to accomplish these tasks you need some lines of code...
I think that ROS/GazeboSim is the best alternative to accomplish these tasks. You will need to learn how to use path planning (deliberative navigation) and reactive navigation. There are some stacks in ROS that will facilitate your job. Take a look in motion planning (OMPL stack) and navigation stack Motion planners and Stack navigation
If your environment is static, probably you know the "map" of environment and you can use a motion planning algorithm to compute the path between the two points. Once the path was planned the next step is execute the actions that will take the robot until the target. So you can collect data sensors using ros-enabled model plugins . Take a look: Gazebo tutorials and ROS-Enabled Plugins
Thanks Daniel, I will try these and let you know if I have any problem.
amit gravatar imageamit ( 2013-02-14 20:25:29 -0500 )edit
Welcome to gazebo simulator and mobile robotics world!
Daniel Vaz gravatar imageDaniel Vaz ( 2013-02-15 03:16:46 -0500 )edit
@ Daniel Vaz : Hi Daniel, I went through the links you suggested. However, I still don't know how to move the robot from one point to another. Can you please tell me the best place where I can find the instructions for moving a pioneer robot ? Is there a code snippet I can look at to get an idea ? Please help. Thanks.
amit gravatar imageamit ( 2013-03-22 10:38:12 -0500 )edit
Try to follow the tutorial: http://www.ros.org/wiki/turtlebot_navigation/Tutorials/Autonomously%20navigate%20in%20a%20known%20map
First learn what is doing with turtle bot, how and when things happens. After try to do it for Pioneer.
Daniel Vaz gravatar imageDaniel Vaz ( 2013-03-22 10:44:06 -0500 )edit
Thanks Daniel...
amit gravatar imageamit ( 2013-03-22 15:14:20 -0500 )edit
Hello sir..I am also starting to work on ros +gazebo,I am also need guidance ...how to interface an external camera with simulator? how to access external network camera access with gazebo and ros...? please I need guidance sir..kindly help me ..
madhu gravatar imagemadhu ( 2016-11-24 08:09:45 -0500 )edit
Asked: 2013-02-13 20:22:10 -0500
Seen: 4,379 times
Last updated: Feb 14 '13
