Trouble importing SVG from tutorial
asked 2016-06-28 16:50:42 -0500
I am having trouble importing the SVG file from the tutorial into gazebo recently installed on mac OSX.
When I select the SVG file from the gazebo GUI, the extracted path shows up correctly as in the tutorial, but once I click OK, it does not appear in the environment.
I have tried this with both my own SVG, and the file available on the tutorial page.
Thanks in advance if anyone can give me some pointers.
Could you run Gazebo in verbose mode and add see if it shows any error messages? If so, please add them to your question. Also mention the Gazebo version you're using.
chapulina gravatar imagechapulina ( 2016-06-28 17:06:45 -0500 )edit
I am running version 7.2.0 After running verbose mode, I get the error message: [Err] [MeshManager.cc:504] GTS library not found. Can not extrude polyline
powertjp1 gravatar imagepowertjp1 ( 2016-06-28 17:17:07 -0500 )edit
answered 2016-06-28 22:42:06 -0500
updated 2016-06-29 10:52:20 -0500
Unfortunately, it looks like SVG extrusion is not working properly on OSX, see this issue.
I tried using *brew install gts* and building gazebo from source, but I still get the same error
powertjp1 gravatar imagepowertjp1 ( 2016-06-29 04:49:42 -0500 )edit
Ah sorry, I overlooked the fact you're using OSX. I updated the answer.
chapulina gravatar imagechapulina ( 2016-06-29 10:53:14 -0500 )edit
Ok, thanks for clarifying
powertjp1 gravatar imagepowertjp1 ( 2016-06-30 04:51:48 -0500 )edit
Asked: 2016-06-28 16:50:42 -0500
Seen: 251 times
Last updated: Jun 29 '16
