Part of the robot wheel is under the ground [closed]
asked 2016-07-20 10:34:55 -0600
zfxw0206 gravatar image
updated 2016-07-20 12:47:30 -0600
I have a robot which has 4 wheels. When I put the robot in gazebo, even though I already set the collision of my wheel, I still find that part of the wheel is under the ground and it is shaking all the time.Here is the image: image description
and the visualization of collision and contact: image description
Does anybody have any idea?
edit retag flag offensive reopen merge delete
Closed for the following reason duplicate question by zfxw0206
close date 2016-07-21 07:43:33.652480
Have you tried turning on collision and contact visualization? That might give you some hints.
chapulina gravatar imagechapulina ( 2016-07-20 12:18:49 -0600 )edit
Yes, I did. I already update my question. Which part shall I pay attention to?
zfxw0206 gravatar imagezfxw0206 ( 2016-07-20 12:48:17 -0600 )edit
Thanks for the screenshot. You could check if the tires have a `<kp>` tag under `collision` -> `contact`. That parameter makes the wheels soft, so the heavier the model, and the higher the kp, the deeper the wheels will penetrate.
chapulina gravatar imagechapulina ( 2016-07-20 12:57:20 -0600 )edit
Thanks for the screenshot. You could check if the tires have a <kp> tag under collision -> contact. That parameter makes the wheels soft, so the heavier the model, and the higher the kp, the deeper the wheels will penetrate.
chapulina gravatar imagechapulina ( 2016-07-20 12:57:44 -0600 )edit
Yes, I increase the "kp", it works. Thank you!
zfxw0206 gravatar imagezfxw0206 ( 2016-07-20 14:13:49 -0600 )edit
Glad it's solved :) I copied the comment into an answer so you can close the question.
chapulina gravatar imagechapulina ( 2016-07-20 15:20:16 -0600 )edit
answered 2016-07-20 15:19:26 -0600
Asked: 2016-07-20 10:34:55 -0600
Seen: 708 times
Last updated: Jul 20 '16
