How can I declare a variable in model.sdf file?
asked 2016-08-05 09:16:20 -0500
Hi everyone,
I hope this is not a silly question. Is there a way to declare a variable in model.sdf file of a robot and use it multiple times? I've made a hexapod and it has some fixed values such as link length or width. If I want to change one leg's values I have to do the same for all the others. I believe this is done by xacro files in ROS but what if I want to do this without ROS?
Thanks in advance!
answered 2016-08-05 12:15:38 -0500
chapulina gravatar image
You could use embedded ruby to generate parametrized models.
  • Here's an example of an SDF model with embedded ruby.
  • Here's an example of an SDF world with embedded ruby.
To regenerate the SDF from the erb template in the command line:
erb model.rsdf > model.sdf
Obs: see this answer.
Thank you so much chapulina! This works very well. I was also thinking of something that I can implement a method in the sdf's API in order to declare a variable or anything I wish. For instance, when I look at the joint.sdf file in the sdformat directory, I can see the joint element's attributes or its elements. I tried to make my own element like declaration.sdf and gave a name and a value as attributes. However it didn't work at all. Would there be another way to do so?
elmuhn gravatar imageelmuhn ( 2016-08-08 05:04:15 -0500 )edit
2 followers
Asked: 2016-08-05 09:16:20 -0500
Seen: 2,224 times
Last updated: Aug 05 '16
