Can't compile custom plugin
asked 2016-08-08 09:06:00 -0600
hassanbot gravatar image
Hi! I'm doing the Gazebo tutorial on making your own plugin. I'm currently on the Control plugin part, but when I try running make (after cmake ..) I get the following error:
~/Developer/Gazebo/velodyne_plugin/build$ make
Scanning dependencies of target velodyne_plugin
[ 50%] Building CXX object CMakeFiles/velodyne_plugin.dir/velodyne_plugin.cc.o
/home/martint/Developer/Gazebo/velodyne_plugin/velodyne_plugin.cc: In member function ‘virtual void gazebo::VelodynePlugin::Load(gazebo::physics::ModelPtr, sdf::ElementPtr)’:
/home/martint/Developer/Gazebo/velodyne_plugin/velodyne_plugin.cc:23:8: error: invalid use of incomplete type ‘class gazebo::physics::Model’
  _model->GetName() << "]\n";
In file included from /usr/include/gazebo-7/gazebo/common/Plugin.hh:49:0,
                 from /usr/include/gazebo-7/gazebo/common/common.hh:34,
                 from /usr/include/gazebo-7/gazebo/gazebo_core.hh:19,
                 from /usr/include/gazebo-7/gazebo/gazebo.hh:20,
                 from /home/martint/Developer/Gazebo/velodyne_plugin/velodyne_plugin.cc:4:
/usr/include/gazebo-7/gazebo/physics/PhysicsTypes.hh:37:11: note: forward declaration of ‘class gazebo::physics::Model’
     class Model;
My code and folder structure is exactly as in the tutorial, and I've installed Gazebo using apt install gazebo7. My OS is Ubuntu 16.04. Gazebo runs fine otherwise, and I've been able to follow several tutorials without errors. Thankful for any help :)
2
answered 2016-08-08 09:48:17 -0600
chapulina gravatar image
See this question. The problem can be solved by adding the following include to your cc file:
#include <gazebo/physics/Model.hh>
Thanks, works like a charm :)
hassanbot gravatar imagehassanbot ( 2016-08-09 03:41:35 -0600 )edit
Asked: 2016-08-08 09:06:00 -0600
Seen: 1,091 times
Last updated: Aug 08 '16
