Plugin to subscribe to nav_msgs/Odometry messages
asked 2016-08-17 14:28:01 -0500
blastpower5 gravatar image
Hi guys,
I am trying to control the movement of a robot inside Gazebo by publishing Odometry messages. I have already written the publisher, but now I'm looking for a way for the robot to subscribe to the topic and follow the commands. I'm not sure if I should be using a plugin (which I haven't found yet) or writing my own subscriber. If I am supposed to write my own subscriber, how should I link it to the robot in Gazebo to control it.
Any help is appreciated, thanks.
answered 2016-08-20 06:29:57 -0500
Hanteus gravatar image
Hi, you have two options, you can use one of the plugins provided by GAZEBO or create a custom one. In the first case, depending on the kinematic that you want, you can use one of the plugin you can find HERE.
In the second case follow THIS tutorial if you publish from ROS or THIS one if you publish from GAZEBO (it's for a transport message but you can easly change it).
I'll also leave here this piece of plugin I'm working on since I had an hard time figuring out how to move the wheels and I think that it could come you handy if you choose the second option:
    // Pointers to the joints of the wheels
    physics::JointPtr leftFrontWheelJoint, rightFrontWheelJoint, leftBackWheelJoint, rightBackWheelJoint;
    // Store the pointer to the joints of the wheels
    leftFrontWheelJoint = this->model->GetJoint("left_front_wheel_hinge");
    // Set the velocity (the first parameter specify the axis of the rotation)
    leftFrontWheelJoint->SetVelocity(0, leftFrontWheelVelocity);
Asked: 2016-08-17 14:28:01 -0500
Seen: 787 times
Last updated: Aug 20 '16
