Problem with launching the gazebo
asked 2016-08-24 02:57:07 -0500
Hi everyone,
I'm a new user in Gazebo, I had program to launch the gazebo in my Ubuntu 16.04.1 LTS 64bit system. It will stuck at preparing your world. It's this due to my computer's problem or some configuration problem?
image description
answered 2016-08-24 10:34:15 -0500
The first time you launch Gazebo, it tries to download some models from the internet. If you wait a while it will eventually start.
Thank you. you are right, I can use it now.
Zero.J gravatar imageZero.J ( 2016-08-25 21:24:44 -0500 )edit
How long do you have to wait? I have the same problem and have been waiting for hours.
spacejunkie gravatar imagespacejunkie ( 2017-01-31 01:11:05 -0500 )edit
It usually depends on your internet connection, but I don't think it should ever wait for hours.
chapulina gravatar imagechapulina ( 2017-01-31 10:39:53 -0500 )edit
having the same problem and I'v been wait for almost more than 2 hours for now...is that normal?
Qdesign gravatar imageQdesign ( 2017-02-09 23:56:36 -0500 )edit
I have the same problem with gazebo 7.8 and ubuntu 16.04.3, somebody figured out how to fix it?
fmazzi gravatar imagefmazzi ( 2017-08-04 09:22:29 -0500 )edit
answered 2017-09-08 11:11:41 -0500
I've run into this problem too, Ubuntu 16.04.2 LTS. I've clicked in 'preparing your world' window, it disapeared. Then ^C, shutdown gazebo, and relaunched the simulator: roslaunch turtlebot_gazebo turtlebot_world.launch. This time looks OK
answered 2018-09-06 04:51:19 -0500
I also struggled with this behaviour. When I ran 'gazebo --verbose' it turned out the reason was that another gazebo server was running in the background:
[Err] [Master.cc:96] EXCEPTION: Unable to start server[bind: Address already in use]. There is probably another Gazebo process running.
Checking the running processes (ps -x | grep gazebo) I found:
4525 pts/2 Sl 14:44 gzserver -s /opt/ros/kinetic/lib/libgazebo_ros_paths_plugin.so -s /opt/ros/kinetic/lib/libgazebo_ros_api_plugin.so
Killing this process (kill -9 4525) solved the problem.
2 followers
Asked: 2016-08-24 02:57:07 -0500
Seen: 5,661 times
Last updated: Sep 06 '18
