Should I Write a Plugin For This? Changing Turtlebot wheel diameter after model loads.
asked 2016-09-23 13:56:48 -0600
ElizabethA gravatar image
I need to change the diameter of the Turtlebot's wheels within a Gazebo simulation. I've found the xacro file in which the wheel diameter is getting set (below).
I'm wondering if writing a plugin to change the wheel diameter is appropriate. My other idea is to make a second Turtlebot URDF with the new wheel diameter, delete the original Turtlebot model from the Gazebo world, and spawn the new one in its place.
Here's where wheel_diameter is set:
<gazebo>
    <plugin name="kobuki_controller" filename="libgazebo_ros_kobuki.so">
     <publish_tf>1</publish_tf>
      <wheel_diameter>0.070</wheel_diameter>
Link to the whole file: https://github.com/yujinrobot/kobuki/...
answered 2016-09-23 16:05:42 -0600
What's wrong with writing a second xacro? You shouldn't need to delete/respawn, however. Find the launch file that called spawn_model, then copy that as your own launch file and change the model to launch your modified version instead.
I'm going to go with the second xacro. My delete/respawn plan is because I'm going to navigate an environment up to a point with one Turtlebot, and then I'm going to switch out that model with Turtlebot model with the wheel adjustment, to simulate a tire going flat. Thanks for your feedback!
ElizabethA gravatar imageElizabethA ( 2016-09-27 15:33:28 -0600 )edit
please accept this answer so others can find it. glad you found it useful
Peter Mitrano gravatar imagePeter Mitrano ( 2016-09-27 16:04:05 -0600 )edit
Asked: 2016-09-23 13:52:02 -0600
Seen: 206 times
Last updated: Sep 23 '16
