Make object stick to Robot
asked 2016-10-21 03:16:17 -0600
Lyndwyrm gravatar image
updated 2016-10-26 09:33:29 -0600
I have a robot that has a platform to transport objects. However, if I place a model on top of that platform and move the robot, the object will stay in its place and eventually fall to the floor. Even if I place a Model from the Gazebo library, so I guess there is somethign wrong with the robot.
How do I make my robot sticky?
right now it has these features:
<!-- Link0 -->
<gazebo reference="${name}_link">
  <selfCollide>true</selfCollide>
  <material>Gazebo/Grey</material>
  <maxVel>1</maxVel>
  <minDepth>0.001</minDepth>
  <dampingFactor>1</dampingFactor>
  <mu1>0.2</mu1>
  <mu2>0.2</mu2>
  <kp>1000000</kp>
  <kd>100000</kd>
  <!--<maxContacts>0</maxContacts>-->
the gazebo.urdf.xacro for the robot:
 <?xml version="1.0"?>
 <robot name="robot_base" xmlns:xacro="http://www.ros.org/wiki/xacro">
   <gazebo>
     <plugin name="gazebo_ros_controller" filename="libgazebo_ros_control.so">
       <robotNamespace>/robot_base</robotNamespace>
 </robot>
the urdf.xacro for the model:
  <xacro:include filename="$(find robot_base)/urdf/robot_base.gazebo.xacro" />
  <xacro:include filename="$(find robot_base)/urdf/robot_base.transmission.xacro" />
  <property name="max_force" value="100.0"/>
  <property name="max_torque" value="100.0"/>
  <property name="max_lin_velocity" value="1.0"/>
  <property name="max_rot_velocity" value="1.0"/>
  <property name="min_position" value="-100.0"/>
  <property name="max_position" value="100.0"/>
  <property name="pi" value="3.14159"/>
  <property name="m" value="400"/> <!--mass of object-->
  <property name="h" value="0.645"/> <!--heigth of object-->
  <property name="l" value="1.204"/> <!--length of object-->
  <property name="w" value="0.72"/> <!--width of object-->
  <xacro:macro name="robot_base_visual_origin">
    <origin xyz="0.542 0 0.065" rpy="0 0 ${pi}"/>
    <material name="Orange"/>
  </xacro:macro>
  <xacro:macro name="robot_base_collision_origin">
    <origin xyz="0.542 0 0.0651" rpy="0 0 ${pi}"/>
  </xacro:macro>
  <xacro:macro name="robot_base_left_arm_mount_origin">
    <origin xyz="0.417 0.175 0.653" rpy="0 0 -1.5707963267948966"/>
    <!--<origin xyz="0.43 0.18 0.645" rpy="0 0 1.5707963267948966"/>-->
  </xacro:macro>
  <xacro:macro name="robot_base_right_arm_mount_origin">
    <origin xyz="0.417 -0.175 0.653" rpy="0 0 -1.5707963267948966"/>
  </xacro:macro>
  <xacro:macro name="robot_base_mast_mount_origin">
    <origin xyz="-0.30 0.230 0.645" rpy="0 0 0"/>
  </xacro:macro>
  <xacro:macro name="robot_base" params="parent_link name hardware_interface">
    <joint name="${name}_fixed_base_joint" type="fixed">
       <!--<axis xyz="0 0 1"/>
      <limit lower="${min_position}" upper="${max_position}" effort="${max_force}" velocity="${max_lin_velocity}"/>-->
       <child link="${name}_virtual_link_0" />
       <parent link="${parent_link}"/>
    <link name="${name}_virtual_link_0">
      <!--<visual>
        <origin xyz="0 0 0.1" rpy="0 0 0" />
          <box size="0.001 0.001 0.001" />
      <collision>
    </collision>-->
        <mass value="0.001" />
        <inertia
          ixx="0.00000001" ixy="0.0" ixz="0.0"
          iyy="0.00000001" iyz="0.0"
          izz="0.00000001" />
    <joint name="${name}_joint_x" type="prismatic">
       <axis xyz="1 0 0"/>
       <limit lower="${min_position}" upper="${max_position ...
(more)
How are you moving your robot? Did you turn on contact visualization and check that the models are indeed touching?
chapulina gravatar imagechapulina ( 2016-10-25 10:26:30 -0600 )edit
I am using postion_controllers/JointTrajectoryController, there are several contacts between the object and the robot. I tried setting the mu coefficients of the object and the robot to Inf, but that didn't change anything.
Lyndwyrm gravatar imageLyndwyrm ( 2016-10-26 05:53:00 -0600 )edit
What version of gazebo are you using? And, can you post your entire model?
nkoenig gravatar imagenkoenig ( 2016-10-26 09:04:42 -0600 )edit
currently using 2.2.3, i hope the model is understandable
Lyndwyrm gravatar imageLyndwyrm ( 2016-10-26 09:31:50 -0600 )edit
answered 2016-11-03 08:52:25 -0600
Created a plugin using Jennifer Buehlers Grasp Plugin as a template.
Asked: 2016-10-21 03:16:17 -0600
Seen: 335 times
Last updated: Nov 03 '16
