Boost not found when building Gazebo from source on Windows
asked 2016-11-11 03:34:15 -0500
Heziva gravatar image
Hello!
The only way I've found to install Gazebo is to build it from source following this page: http://gazebosim.org/tutorials?tut=in...
I am stuck when I try to install sdformat: the windows command prompt says it cannot find boost. I do have boost in the directory its looking at. I've tried to download a more recent version of Boost and to alter configure.bat accordingly without success. I've tryed to set BOOST_ROOT and BOOST_LIBRARYDIR to the correct path in the console, doesn't change a thing.
How might I install Gazebo on my windows machine?
====== Finding 3rd Party Packages ======
-- Using internal tinyxml code
-- Operating system is Windows
-- Could NOT find PkgConfig (missing:  PKG_CONFIG_EXECUTABLE)
-- Building for arch: x86_64
-- Boost version: 1.56.0
CMake Error at C:/Program Files/CMake/share/cmake-3.7/Modules/FindBoost.cmake:17
93 (message):
  Unable to find the requested Boost libraries.
  Boost include path: D:/Jonathan/Gazebo/gz-ws/boost_1_56_0
  Could not find the following Boost libraries:
          boost_system
          boost_filesystem
          boost_program_options
          boost_regex
          boost_iostreams
  No Boost libraries were found.  You may need to set BOOST_LIBRARYDIR to the
  directory containing Boost libraries or BOOST_ROOT to the location of
  Boost.
Call Stack (most recent call first):
  cmake/SearchForStuff.cmake:18 (find_package)
  CMakeLists.txt:107 (include)
--      Boost not found. Please install thread signals system filesystem program
_options regex boost version  or higher.
-- Could NOT find PY_psutil (missing:  PY_PSUTIL)
--      Python psutil package not found. Memory leak tests will be skipped
-- Found ruby executable: D:/Jonathan/prog/Ruby23-x64/bin/ruby.exe
answered 2016-11-23 00:08:46 -0500
Vaidehi gravatar image
This error exists when the compiler is not able to find the "lib" folder in the boost directory. I had faced this same issue while installing Gazebo but it solved when I renamed the directory lib64-msvc-12.0 to lib.
Please go to the directory D:/Jonathan/Gazebo/gz-ws/boost_1_56_0 and check if there exists a folder that contains .dll as well as .lib files with names beginning as mentioned in the error message as
  • boost_system
  • boost_filesystem
  • boost_program_options
  • boost_regex
  • boost_iostreams
Rename that directory to lib and the ..\configure command will install sdformat without error.
Asked: 2016-11-11 03:32:41 -0500
Seen: 713 times
Last updated: Nov 11 '16
