Windows install missing libqwt-dev
asked 2016-11-28 20:14:24 -0600
goldbeezie gravatar image
I'm trying to install gazebo on windows 10, and when I run "..\configure" in gazebo/build (step 11 in the tutorial), I get the error: "Missing: libqwt-dev. Required for plotting"
I've downloaded qwt-6.1.2, but it doesn't seem to fix it. Does anyone know how I can fix this?
Thanks
you might have to set some CMake variables, such as the include or library path. Check out the variables in the configure script. That would be the right place to add stuff. You can also check out the jenkins build. maybe that will help? http://build.osrfoundation.org/view/main/view/GazeboDefault/job/gazebo-ci-default-windows7-amd64/406/
Peter Mitrano gravatar imagePeter Mitrano ( 2016-11-28 23:48:18 -0600 )edit
answered 2016-11-30 19:31:27 -0600
scpeters gravatar image
Here's the Jenkins script we use to build gazebo on windows:
It downloads qwt and a few other things and extracts it in a specific location.
Hope this helps.
gb96 gravatar imagegb96 ( 2017-11-22 19:37:13 -0600 )edit
2 followers
Asked: 2016-11-28 20:14:24 -0600
Seen: 375 times
Last updated: Nov 30 '16
