error in simple plugin for an AUV
asked 2016-12-28 03:38:00 -0500
Hi, I am new to gazebo. I had written a Matlab code for nonlinear dynamics of an AUV , now I need to connect my simulink code to gazebo. I am not using the physics of gazebo as the physics is going to be controlled from simulink.
I create a model of the AUV in gazebo and setup the joints for the propeller, rudder and elevator.
image description
However, I am having difficulty understanding the plugin tutorials.
I copy and modified the code from herelink text
I am trying to compile the plugin but I am having error:
[ 50%] Building CXX object CMakeFiles/remusbody.dir/remusbody.cc.o /home/wilmer/catkin_ws/src/plugins/remusbody.cc:5:33: fatal error: geometry_msgs/Twist.h: No such file or directory compilation terminated. CMakeFiles/remusbody.dir/build.make:62: recipe for target 'CMakeFiles/remusbody.dir/remusbody.cc.o' failed make[2]: * [CMakeFiles/remusbody.dir/remusbody.cc.o] Error 1 CMakeFiles/Makefile2:355: recipe for target 'CMakeFiles/remusbody.dir/all' failed make[1]: [CMakeFiles/remusbody.dir/all] Error 2 Makefile:138: recipe for target 'all' failed make: ** [all] Error 2
what I am doing wrong?
I attach this line to package.xml
<build_depend>geometry_msgs</build_depend>
My cmakelist is this
cmake_minimum_required(VERSION 2.8 FATAL_ERROR)
find_package(gazebo REQUIRED)
find_package(catkin REQUIRED COMPONENTS roscpp geometry_msgs)
 add_library(remusbody SHARED remusbody.cc)
 target_link_libraries(remusbody ${GAZEBO_LIBRARIES})
 include_directories(${GAZEBO_INCLUDE_DIRS})
 link_directories(${GAZEBO_LIBRARY_DIRS})
 list(APPEND CMAKE_CXX_FLAGS "${GAZEBO_CXX_FLAGS}")
My plugin code is attached down.
any help is welcome...
#include <stdio.h>
#include <geometry_msgs/Twist.h>
#include "geometry_msgs/PoseStamped.h"
#include "gazebo/gazebo.hh"
#include "gazebo/physics/physics.hh"
#include "gazebo/common/common.hh"
#include "math/Vector3.hh"
#include <math/gzmath.hh>
static float Vlin=0.0, Vang=0.0; // set as global
namespace gazebo
  class ROSModelPlugin : public ModelPlugin
    public: ROSModelPlugin()
      // Start up ROS
      std::string name1 = "gz"; // this is what appears in the rostopics
      int argc = 0;
      ros::init(argc, NULL, name1);
    public: ~ROSModelPlugin()
      delete this->nh;
      this->model = _parent;
      // ROS Nodehandle
      this->nh = new ros::NodeHandle("~");
      // ROS Subscriber
      this->subvel = this->nh->subscribe<geometry_msgs::Twist>("cmd_vel", 1000, &ROSModelPlugin::ROSCallback_Vel, this );
      this->pubpose = this->nh->advertise<geometry_msgs::PoseStamped>("pose",1000);
      // simulation iteration.
      // for gazebo 1.4 or lower it should be ConnectWorldUpdateStart
      boost::bind(&ROSModelPlugin::OnUpdate, this));
    public: void OnUpdate()
      std::vector<double> rangesgz;
        static double qw,qx,qy,qz, Rrad, Prad, Yrad;
// ************* QUATERNION / POSE DATA ******************
      math::Vector3 p = model->GetWorldPose().pos;
      math::Quaternion r = model->GetWorldPose().rot;
      //from quaternion to Roll Pitch Yaw, in radianos
      qw=r.w;   qx=r.x;     qy=r.y;     qz=r.z;
      Rrad=atan2(  2*(qw*qx+qy*qz),  1-2*(qx*qx+qy*qy)  );  //Roll
      Prad=asin(2*(qw*qy-qz*qx));               //Pitch
      Yrad=atan2(  2*(qw*qz+qx*qy),  1-2*(qy*qy+qz*qz)  );  //Yaw
        ros::Time current_time ...
(more)
answered 2017-01-04 21:26:02 -0500
wilmer gravatar image
I found the error was in package.xml, there was multiple errors.
In theory this plugin should move an object in the enviroment. i had to test the plugin with my robot
thank you for your help chapulina
if someone see an error please write a comment
my plugin at the moment is:
    #include <boost/bind.hpp>
    #include <gazebo/gazebo.hh>
    #include "geometry_msgs/Twist.h"
    #include <stdio.h>
    static float velx=0.0,vely=0.0,velz=0.0,Vangx=0.0,Vangy=0.0, Vangz=0.0; // set as global
    namespace gazebo
      class remusbody : public ModelPlugin
              boost::bind(&remusbody::OnUpdate, this, _1));
        // callback functions run every time data is published to the topic
        void ROSCallback_Vel(const geometry_msgs::Twist::ConstPtr& msg)
            velx=msg->linear.x;
            vely=msg->linear.y;
            velz=msg->linear.z;
            Vangx=msg->angular.x;
            Vangy=msg->angular.y;
            Vangz=msg->angular.z;
        public: void OnUpdate(const common::UpdateInfo & /*_info*/)
          // Apply a small linear velocity to the model.
          this->model->SetLinearVel(math::Vector3(velx, vely, velz));
           this->model->SetAngularVel(math::Vector3(Vangx, Vangy, Vangz));
        // Pointer to the model
      GZ_REGISTER_MODEL_PLUGIN(remusbody)
my cmakelist is
    cmake_minimum_required(VERSION 2.8.3)
    project(plugins)
    # Load catkin and all dependencies required for this package
      roscpp
      gazebo_ros
      geometry_msgs
    # Depend on system install of Gazebo
    set(CMAKE_CXX_FLAGS "-std=c++0x ${CMAKE_CXX_FLAGS}")
    include_directories(${Boost_INCLUDE_DIR} ${catkin_INCLUDE_DIRS} ${GAZEBO_INCLUDE_DIRS})
    add_library(plugins SHARED remusbody.cc)
    target_link_libraries(${PROJECT_NAME} ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
    catkin_package(
      DEPENDS
        roscpp
        gazebo_ros
        geometry_msgs
and my package.xml inside my plugin folder is
    <?xml version="1.0"?>
    <package>
      <name>plugins</name>
      <version>0.0.0</version>
      <description>The plugins wilmer_gazebo package</description>
      <maintainer email="wilmer@todo.todo">wilmer</maintainer>
      <license>TODO</license>
      <buildtool_depend>catkin</buildtool_depend>
      <build_depend>roscpp</build_depend>
      <build_depend>rospy</build_depend>
      <build_depend>gazebo_ros</build_depend>
      <build_depend>std_msgs</build_depend>
      <run_depend>roscpp</run_depend>
      <run_depend>rospy</run_depend>
      <run_depend>gazebo_ros</run_depend>
      <run_depend>std_msgs</run_depend>
      <run_depend>geometry_msgs</run_depend>
      <!-- The export tag contains other, unspecified, tags -->
      <export>
        <!-- Other tools can request additional information be placed here -->
      </export>
    </package>
answered 2017-01-03 22:42:27 -0500
chapulina gravatar image
Have you installed the geometry messages? For example:
sudo apt-get install ros-kinetic-geometry-msgs
hi, nop that is not the problem. I runed and i get this ros-kinetic-geometry-msgs is already the newest version (1.12.5-0xenial-20161026-181759-0700). ros-kinetic-geometry-msgs set to manually installed. 0 to upgrade, 0 to newly install, 0 to remove and 166 not to upgrade. can you tell me what are the step to compile a plugin? why i have to add to package.xml can you check my cmakelist, maybe the errors is there. i added to my initial question
wilmer gravatar imagewilmer ( 2017-01-04 17:48:47 -0500 )edit
Asked: 2016-12-28 03:38:00 -0500
Seen: 711 times
Last updated: Jan 04 '17
