Pose and orientation of my robot is incorrect in Gazebo and RViz
asked 2017-01-04 23:45:47 -0600
Pose and orientation of my robot is incorrect in Gazebo and RViz .
I have exported the URDF from Solidworks using solidworks to URDF plugin. I didn't modify any option in dialogues opened during export. Then i created an URDF package in ROS workspace and spawned the robot model into the world which resulted in inverted pose of the robot as shown in picture.
when load model in gazebo and Rviz from starting have this pose . how can edit my urdf or xacro file to load robot correctly ?? my xacro file : https://www.dropbox.com/sh/d4wjdjie1s...
image description
Could it have fallen to the ground? Have you tried starting the simulation paused?
chapulina gravatar imagechapulina ( 2017-01-05 00:22:20 -0600 )edit
try to reset the model and position
wilmer gravatar imagewilmer ( 2017-01-05 01:09:23 -0600 )edit
yes . i paused simulation. robot is fallen to the ground in RViz too !
zakizadeh gravatar imagezakizadeh ( 2017-01-05 01:40:22 -0600 )edit
where is the 0,0,0 in your solidworks? by the look is not in the base. can you edit your model from the gui and capture the screen?
wilmer gravatar imagewilmer ( 2017-01-05 14:06:46 -0600 )edit
Did you pause the simulation after it had already started or you started the simulation paused? You can set `paused:=true` when you launch it.
chapulina gravatar imagechapulina ( 2017-01-05 17:10:46 -0600 )edit
The reason I think it fell is that it looks like that on your screenshot.
chapulina gravatar imagechapulina ( 2017-01-05 17:11:57 -0600 )edit
zakizadeh gravatar imagezakizadeh ( 2017-01-05 19:40:17 -0600 )edit
hi . I Tried so hard but I still have problems . I'm disappointed . can you help me please ! i need your help
zakizadeh gravatar imagezakizadeh ( 2017-01-16 08:08:27 -0600 )edit
