How to properly use get_sensor?
asked 2017-01-16 03:37:56 -0600
Robot_sim_person gravatar image
I have some code which uses get_sensor to get a laser sensor, however when I want to use two of this model, they get muddled up as I can't reference the full model name.
sensors::SensorPtr model_sensor;
model_sensor = sensors::get_sensor("laser"); // this is fine when there's only one laser sensor
I want to get something like:
model_sensor = sensors::get_sensor("my_model::hoyoko::link::laser"); but I'm confident this is wrong as gazebo crashes with this new code.
I have the get_sensor refference : http://osrf-distributions.s3.amazonaw... (Ctrl f "get_sensor" to find the relevant part)
But I don't fully understand what they mean by " This name should be fully scoped. This means _name = world_name::model_name::link_name::sensor_name."
Any help would be much appreciated, thanks!
answered 2017-01-17 08:39:39 -0600
It turns out you can either use just the sensor_name for the string, or the whole thing. But nothing in between (i.e. "model_name::link_name::sensor_name" is not acceptable.
An easy way to get an example of this is to print GetScopedName() on the terminal ( "model_sensor->GetScopedName()" ) .
Thanks for posting your solution. I'm curious, what do you mean by "the whole thing" if it's not the scoped name? Maybe this is a bug in Gazebo, it shouldn't crash with a bad string.
chapulina gravatar imagechapulina ( 2017-01-17 12:19:51 -0600 )edit
If I try to find the sensor without the world name, i.e: sensorLocation = /*"default::" +*/ this->model->GetName() + "::hokuyo::link::laser"; the get_sensor function will crash. But it will work fine if I either include all the names, or just the sensor name. The whole thing is: sensorLocation = "default::" + this->model->GetName() + "::hokuyo::link::laser"; Just the sensor name is: sensorLocation = "laser";
Robot_sim_person gravatar imageRobot_sim_person ( 2017-01-18 04:19:19 -0600 )edit
Thanks for the clarification
chapulina gravatar imagechapulina ( 2017-01-18 11:03:22 -0600 )edit
Asked: 2017-01-16 03:37:56 -0600
Seen: 144 times
Last updated: Jan 17 '17
