gazebo7 trying to load libgazebo.so.8
asked 2017-02-07 16:46:01 -0600
ckchow gravatar image
When I try to start gazebo 7, gzserver reports an error that it can't open libgazebo.so.8. I've installed from debs on ubuntu 16.04. I have checked ldconfig and the rest of my filesystem and I can't find any trace of libgazebo8.
answered 2017-02-07 18:06:28 -0600
I imagine this is related to this question.
If you've mixed a lot of different source and deb install versions, I recommend you apt remove everything related to gazebo, ignition and sdformat, and make uninstall from the build directories. After that, dig around your /usr directory and delete anything related to gazebo, ignition and sdformat that you can find.
After all this you should be in a relatively clean state. But to be sure, when installing Gazebo 7 from debs, use the --reinstall flag:
sudo apt install gazebo7 --reinstall
I figured out that the busted source installs that I had done had created bad versions of gzclient and gzserver that were linked to libgazebo8. I had tried `make uninstall`, and it would probably have gotten rid of gzserver and friends, but the make commands were all broken because I had uninstalled libignition and some other dependencies already.
ckchow gravatar imageckchow ( 2017-02-09 14:04:37 -0600 )edit
Glad you solved the problem. This kind of thing happens to me all the time.
chapulina gravatar imagechapulina ( 2017-02-09 14:07:40 -0600 )edit
Asked: 2017-02-07 16:46:01 -0600
Seen: 241 times
Last updated: Feb 07 '17
