What did I miss from my model?
asked 2017-02-08 01:56:02 -0600
ThangNguyen gravatar image
updated 2017-02-08 02:05:06 -0600
Hi, I am trying to create a different drive mobile robot model. Could you please tell me what did I miss from my model which make the wheel go though the ground?
Beside that I need help to verify if the way I use origin correct or not.
C:\fakepath\Screenshot from 2017-02-08 03-04-20.png
Thank you very much for your help.
Below is my file
<?xml version="1.0"?>
<!-- Add Mass + Inertia-->
<robot name="differential_drive_robot">
    <material name="Black">
            <color rgba="0.0 0.0 0.0 1.0"/>
    <material name="Red">
            <color rgba="0.8 0.0 0.0 1.0"/>
    <material name="White">
            <color rgba="1.0 1.0 1.0 1.0"/>
    <material name="Blue">
            <color rgba="0.0 0.0 0.8 1.0"/>
    <link name="base_link">
        <visual>
            <origin xyz="0.0 0.0 0.04"/>
                <cylinder length="0.02" radius="0.15"/>
            <material name="White"/>
        <collision>
            <mass value="5"/>
            <inertia ixx="0.0282916666667" ixy="0" ixz="0" iyy="0.0282916666667" iyz="0" izz="0.05625"/>
        <material>Gazebo/Gray</material>
    <joint name="right_wheel_joint" type="continuous">
        <origin xyz="0.15 0.0 0.04"/>
        <parent link="base_link"/>
        <child link="right_wheel"/>
        <axis xyz="1 0 0" />
    <link name="right_wheel">
        <visual>
            <origin xyz="0.0 0.0 0.0" rpy="0 1.57075 0"/>
                <cylinder length="0.02" radius="0.04"/>
        <collision>
            <mass value="2.5"/>
            <inertia ixx="0.002" ixy="0" ixz="0" iyy="0.001083" iyz="0" izz="0.001083"/>
    <gazebo reference="right_wheel">
    <joint name="left_wheel_joint" type="continuous">
        <origin xyz="-0.15 0.0 0.04"/>
        <child link="left_wheel"/>
    <link name="left_wheel">
        <visual>
        <collision>
            <mass value="2.5"/>
    <gazebo reference="left_wheel">
    <joint name="front_caster_joint" type="fixed">
        <origin xyz="0.0 0.12 0.016"/>
        <child link="front_caster"/>
    <link name="front_caster">
        <visual>
                <sphere radius="0.014"/>
            <material name="Blue"/>
        <collision>
            <mass value="2.5"/>
            <inertia ixx="0.000125" ixy="0" ixz="0" iyy="0.000125" iyz="0" izz="0.000125"/>
    <joint name="rear_caster_joint" type="fixed">
        <origin xyz="0.0 -0.12 0.016"/>
        <child link="rear_caster"/>
    <link name="rear_caster">
        <visual>
        <collision>
            </geometry ...
(more)
Please give me advice on if I use origin correct or not, since I am learning. Thank you.
ThangNguyen gravatar imageThangNguyen ( 2017-02-08 11:26:18 -0600 )edit
answered 2017-02-14 06:08:20 -0600
TTDM gravatar image
Can you try adding your origin bloc to the collision too ? At the moment, you are indeed seing verticals wheels (cylinders) but the collision block is not checking thoses verticals cylinder but some horizontal ones.
Try visualizing collisions, inertia, and contacts in the Gazebo GUI. These visual should debug a model problem.
nkoenig gravatar imagenkoenig ( 2017-02-14 09:11:56 -0600 )edit
Thank you very much for your answer.
ThangNguyen gravatar imageThangNguyen ( 2017-02-14 23:10:58 -0600 )edit
Asked: 2017-02-08 01:56:02 -0600
Seen: 100 times
Last updated: Feb 14 '17
