How does getChild() and getChildCount() work?
asked 2017-02-13 07:21:22 -0600
lysgaard gravatar image
I am making a plugin for this model:
<?xml version="1.0"?>
<sdf version="1.4">
  <model name="my_model">
      <gravity>true</gravity>
      <inertial>...</inertial>
      <sensor name="camera" type="camera">
        <pose>0 0 0 0 0 0</pose>
          <horizontal_fov>2.0</horizontal_fov>
            <width>640</width>
            <height>480</height>
            <near>1.0</near>
            <far>15000</far>
        <update_rate>10</update_rate>
        <visualize>1</visualize>
      <collision name="collision">...</collision>
      <visual name="visual">...</visual>
    <plugin name="myplugin" filename="libmyplugin.so"/>
In the plugin I want to manipulate the pose of the camera. The code I use to do this is:
gazebo::physics::BasePtr base = _model->GetLink()->GetChild(std::string("camera"));
if(base){
    boost::dynamic_pointer_cast<gazebo::sensors::CameraSensor>(base)->SetPose(pose);
Interestingly base always ends up being a nullptr.
When I call
_model->GetLink()->GetChildCount()
I get the children count of 1.
If I call
_model->GetLink()->GetChild(0)->GetName()
I get "collision". So it seems like the only children to the <link> is the <collision>. This seems quite unlogical for me and I am stuck. I also tried adding another collision tag to the model SDF, GetChildCount then increases to 2, and both collisions can be listed. Is there something about the semantics of GetChild() that I do not understand? I thought I could manipulate the camera using it?
answered 2017-02-13 11:55:15 -0600
chapulina gravatar image
updated 2017-02-13 11:56:52 -0600
The gazebo::physics library deals with physics entities, such as models, links and collisions. Therefore, when you get a child entity, you get one of these physics objects.
Sensors are handled by a separate library, gazebo::sensors. I can see how that can be confusing, but even though the camera sensor is a child of the link in SDF, it isn't a child for the physics library. The maximum the physics library can give you is the name and number of sensors, but no pointers. Take a look at these functions:
To get a pointer to the camera sensor, you'll have to use the sensor library like this for example:
auto camera = sensors::SensorManager::Instance()->GetSensor("my_model::link::camera");
Thanks for the good answer. Might I suggest that the `GetChild()` and `GetChildCount()` documentation is updated to include a note about it's limitations, and maybe even a link to other possibly wanted functions like `GetSensor()`?
lysgaard gravatar imagelysgaard ( 2017-02-14 03:13:27 -0600 )edit
chapulina gravatar imagechapulina ( 2017-02-14 09:41:32 -0600 )edit
Asked: 2017-02-13 07:21:22 -0600
Seen: 297 times
Last updated: Feb 13 '17
