ROS SubscriberOptions problem in tutorial code
asked 2017-02-13 14:18:24 -0600
Cdfghglz gravatar image
Hi there,
following the tutorials (up to project structure) I ran into the following error:
[Err] [Model.cc:1256] Exception occured in the Load function of plugin with name[velodyne_control] and filename[/home/cdfghglz/WS/gazebo/plugins/velodyne/build/libvelodyne_plugin.so]. This plugin will not run.
I suspect the following to be the culprit:
image description
Also it seems like the ros/subscribe_options.h is not being used. Any ideas what might cause this?
Thanks!
