Gazebo 7 exits with code 255 but no error messages
asked 2017-02-28 16:11:09 -0500
Zabot gravatar image
updated 2017-03-03 13:22:51 -0500
I recently installed gazebo 7 to use with ros after removing gazebo 8. Gazebo 8 worked without issue, however gazebo 7 silently exits with code 255 after flashing the main UI for just a moment.
~$ gazebo --verbose
Gazebo multi-robot simulator, version 7.5.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.105
~$ echo $?
255
Graphics card info:
~$ lspci | grep VGA
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Whistler [Radeon HD 6730M/6770M/7690M XT]
After some more investigation, gzserver runs without issue, gzclient segfaults. Here's the stack trace:
#0  0x00007fff882760e0 in ?? ()
#1  0x00007ffff71ea103 in QFactoryLoader::instance(QString const&) const ()
    from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#2  0x00007ffff5407dd1 in QIcon::addFile(QString const&, QSize const&, QIcon::Mode, QIcon::State) ()
    from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#3  0x00007ffff540811a in QIcon::QIcon(QString const&) ()
#4  0x00007ffff7833e2a in gazebo::gui::ModelEditor::ModelEditor(gazebo::gui::MainWindow*) ()
    from /usr/lib/x86_64-linux-gnu/libgazebo_gui.so.7
#5  0x00007ffff76e07e8 in gazebo::gui::MainWindow::CreateEditors() ()
#6  0x00007ffff76eecd4 in gazebo::gui::MainWindow::MainWindow() ()
#7  0x00007ffff76b7630 in gazebo::gui::load() ()
#8  0x00007ffff76b77c4 in gazebo::gui::run(int, char**) ()
#9  0x00000000004013aa in ?? ()
#10 0x00007ffff6536830 in __libc_start_main (main=0x401390, argc=1,
argv=0x7fffffffdd88, init=<optimized out>, fini=<optimized out>,
rtld_fini=<optimized out>, stack_end=0x7fffffffdd78)
at ../csu/libc-start.c:291
#11 0x0000000000401459 in _start ()
When you uninstalled Gazebo8, did you uninstall ignition and sdformat packages as well?
chapulina gravatar imagechapulina ( 2017-02-28 20:25:07 -0500 )edit
Just double checked to make sure, `libsdformat5` and `libignition-math3` are both installed and up to date.
Zabot gravatar imageZabot ( 2017-03-01 12:50:00 -0500 )edit
could you please try: 1. apt-get remove .*gazebo.* and 2. paste in pastebin.com the result of find /usr -name '*gazebo*'. Thanks
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2017-03-01 17:14:21 -0500 )edit
answered 2017-03-03 14:24:12 -0500
I probably solved this with a sledgehammer rather than a scalpel, but after sudo apt-get purge libqt* and a reinstall following the Qt 5 Ubuntu Installation Instructions, gazebo7 is working as expected. Thanks to iche033 for the suggestion.
answered 2017-03-01 16:42:39 -0500
Ok, so it looks like you first installed Gazebo 8 and all its dependencies, and then installed Gazebo 7 on top of that.
The problem is, Gazebo 7 uses sdformat4 and ignition-math2, while Gazebo 8 uses sdformat5 and ignition-math3. And, unfortunately, these are all incompatible :(
So I suggest you uninstall all of Gazebo and its dependencies once again, to have a clean start, and then install Gazebo 7, which should pull the correct dependencies only.
This should perform the uninstallation:
sudo apt-get remove '.*gazebo.*' '.*sdformat.*' '.*ignition.*'
So I removed gazebo, all the libraries, and the ros packages for good measure and installed `gazebo7`, still getting the same issue. The install did pull the right dependencies, `libignition-math2` and `libsdformat4` are both installed.
Zabot gravatar imageZabot ( 2017-03-01 16:56:49 -0500 )edit
there is also Qt linking issue: https://bitbucket.org/osrf/gazebo/issues/2215/gazebo-9-link-with-wrong-qt. Just to be sure, I would uninstall Qt5 and try again
iche033 gravatar imageiche033 ( 2017-03-03 13:42:35 -0500 )edit
Asked: 2017-02-28 16:11:09 -0500
Seen: 464 times
Last updated: Mar 03 '17
