ARIAC UR10 Arm Controller Spawner Hangs on Launch [closed]
asked 2017-03-03 19:11:07 -0600
RandomWord gravatar image
Hi, I'm trying to bring up the ARIAC sim as per the GEAR tutorial. I built it from source and it generated no build errors. I'm launching it with the following command:
rosrun osrf_gear gear.py -f "$(catkin_find --first-only --share osrf_gear)/config/sample.yaml"
The simulation comes up, the arm spawns, the parts show up, but the arm_controller_spawner hangs in a sleep and never finishes, so the /ariac/arm topics are never published.
The rosrun output and stack trace is here: http://pastebin.com/fGDvz09L
I've seen other issues where the arm controller can't be found because of a missing package, but I'm not receiving similar errors and have those packages installed.
Thanks for any help you can provide.
edit retag flag offensive reopen merge delete
Closed for the following reason question is off-topic or not relevant by Carlos Agüero
close date 2017-03-10 12:03:08.938612
answered 2017-03-10 12:01:13 -0600
Carlos Agüero gravatar image
updated 2017-03-10 12:04:10 -0600
Could you move this issue to the ARIAC issue tracker, please?
https://bitbucket.org/osrf/ariac/issues
I'm closing the question here, is a totally valid question, but it's better to file it on the ARIAC repository.
Asked: 2017-03-03 19:11:07 -0600
Seen: 143 times
Last updated: Mar 10 '17
