How to: move a simple box in the air
asked 2017-04-04 03:11:35 -0500
MSI gravatar image
Hello all,
I would like to have a simple box moving in the air with a precise position/speed.
What I did so far is to create an SDF model with 3 prismatic joints fixed to the root. Then the joints are controlled by PID controllers (YARP's controlBoard). The PID-tuning was a bit complicated and it results that the speed and the position are not accurate enough for my purpose.
How would you get a "hard defined position / speed" controller working?
Best
Is the box going to collide with other objects in simulation?
chapulina gravatar imagechapulina ( 2017-04-04 14:28:32 -0500 )edit
not at all, it will be a screen that displays images to the actual robot
MSI gravatar imageMSI ( 2017-04-05 02:18:33 -0500 )edit
In that case, the animation suggestion below is convenient, but it might be hard to specify a very precise trajectory. If you need precision, you could make the model static and call SetWorldPose on it.
chapulina gravatar imagechapulina ( 2017-04-05 11:30:44 -0500 )edit
answered 2017-04-04 14:12:52 -0500
nkoenig gravatar image
You could animate the box
thank you for your answer, I'll check that out!
MSI gravatar imageMSI ( 2017-04-05 02:20:02 -0500 )edit
Asked: 2017-04-04 03:11:35 -0500
Seen: 154 times
Last updated: Apr 04 '17
