How to remove or respawn robots during the simulation?
asked 2017-04-20 02:45:21 -0600
jasonwang538@gmail.com gravatar image
Hi everyone
I am a new gazebo user. Currently, I am implementing an algorithm by using Ros platform with Gazebo simulator. I will use a group of robot (at least 10 hector quadrotors) for the simulations. And under some certains conditions, the robot need to be removed or respawned during the simulation.
I use .cpp file as a rosnode to run the controllers (algorithm) for all robots. Does anyone know how to realize this dynamic removal or respawn through .cpp file? or .launch file?
Thank you very much
answered 2017-04-21 09:07:29 -0600
winston gravatar image
There are two methods in general:
  1. You could use a ROS service call as @iche033 has said. But you need to install gazebo_ros package first.
  2. You could use Gazebo's built-in functions. There are a couple of functions which can insert or delete a model in gazebo::physics::World Class (link). For example, RemoveModel (const std::string &_name) to remove a model or InsertModelFile (const std::string &_sdfFilename) to insert a model.
Thanks for your answer.
jasonwang538@gmail.com gravatar imagejasonwang538@gmail.com ( 2017-04-21 11:02:27 -0600 )edit
Hi, sorry for asking another issue. I use a .xacro file for descripting the robot instead of the .urdf format. In terms of gazebo_msgs/SpawnModel message type, for the field of model_xml, can I still use .xacro file? Or I need to convert .xacro into .urdf then assign it to the model_xml field? Because I do not know how to convert .xacro to .urdf in c++ file.
jasonwang538@gmail.com gravatar imagejasonwang538@gmail.com ( 2017-04-21 11:40:11 -0600 )edit
I am not sure but I think .xacro should be OK. Why not have a try? BTW, if you have fond the satisfied answer to your question, please tick it as the best answer so that other people who may have the same problem could find out the answer as fast as possible.
winston gravatar imagewinston ( 2017-04-23 23:39:48 -0600 )edit
I am not sure but I think .xacro should be OK. Why not have a try? BTW, if you have found the satisfied answer to your question, please tick it as the best answer so that other people who may have the same problem could find out the answer as fast as possible.
winston gravatar imagewinston ( 2017-04-23 23:40:05 -0600 )edit
answered 2017-04-20 11:27:40 -0600
iche033 gravatar image
you can probably just use ros services to spawn and delete models. See this tutorial
Thank you very much for telling me this. But, could you tell me a little bit more about this? I use .cpp file as a executable for controlling the robot. But I do not know which Gazebo API can release this. Do you know some avaible class or APIs? I am grateful for any reply from you.
jasonwang538@gmail.com gravatar imagejasonwang538@gmail.com ( 2017-04-20 12:22:47 -0600 )edit
Thanks, really helpful. I will go through this page.
jasonwang538@gmail.com gravatar imagejasonwang538@gmail.com ( 2017-04-21 10:38:24 -0600 )edit
Asked: 2017-04-20 02:45:21 -0600
Seen: 2,899 times
Last updated: Apr 21 '17
