Debug Gazebo (without ROS) using GDB
asked 2017-05-09 15:06:48 -0600
dbrodeur gravatar image
How is it possible to use gdb to debug Gazebo.
I do not use ROS, only Gazebo 7 on Ubuntu 14.04 (a bit old but I have other dependencies that require me to use 14.04). I built Gazebo from source and it worked fine. Following the instructions I used the command :
cmake -DCMAKE_BUILD_TYPE=Debug ../
to make sure I will be able to use gdb but when I start the program with gdb and I make the program crash, the stack is always empty. Should this be because I did not configure or start gdb correctly?
Are you starting gzserver and gzclient separately? Running gdb on both?
chapulina gravatar imagechapulina ( 2017-05-09 15:26:48 -0600 )edit
No I was running both at the same time using gazebo instead of gzserver <world> and then gzclient as was suggested to me on the other answer below. Thanks for your help!
dbrodeur gravatar imagedbrodeur ( 2017-05-10 07:25:34 -0600 )edit
answered 2017-05-09 15:30:37 -0600
Carlos Agüero gravatar image
Instead of using gazebo, you have to use gzserver <world>, and then, gzclient.
E.g. for debugging gzserver:
gdb gzserver
r <your_world>
Once gzserver is running, you can launch gzclient if you want.
Alternatively, you can just launch gzserver as usual:
gzserver <your_world>
And run gdb on gzclient with:
gdb gzclient
r
Take a look at this related question too.
Ah you're right! I was running both server and client at the same time. Thanks it works!
dbrodeur gravatar imagedbrodeur ( 2017-05-10 07:21:28 -0600 )edit
Asked: 2017-05-09 15:06:48 -0600
Seen: 1,417 times
Last updated: May 09 '17
