(Solved)xacro: Traditional processing is deprecated?
asked 2017-05-10 06:24:05 -0600
Hello everyone.
I am trying to display a model in gazebo and I get the following warning:
image description
xacro: Traditional processing is deprecated. Switch to --inorder processing! To check for compatibility of your document, use option --check-order. For more infos, see http://wiki.ros.org/xacro#Processing_... xacro.py is deprecated; please use xacro instead
How can i solve this?
This sounds like an XY problem. Is there a larger problem you're trying to solve? The xacro warning is just a warning. It means the robot description is written using xacro, and the roslaunch for it is not passing the --inorder flag. If you have written the robot description and the launch file then follow the link in your answer for instructions on making the warning go away. Otherwise it can be safely ignored.
sloretz gravatar imagesloretz ( 2017-05-10 11:31:21 -0600 )edit
How do I get the launch file to pass the --inorder flag? Should I add a line of code to the launch file to run inorder?
Daniel Tobon gravatar imageDaniel Tobon ( 2017-05-11 07:19:15 -0600 )edit
Use the args attribute on the node tag http://wiki.ros.org/roslaunch/XML/node
sloretz gravatar imagesloretz ( 2017-05-11 09:09:47 -0600 )edit
2
answered 2017-05-23 19:46:43 -0600
updated 2017-05-23 19:48:29 -0600
the solution is in the launch file:
< param name="robot_description" command="$(find xacro)/xacro --inorder $(arg model)" />
answered 2018-10-06 13:05:52 -0600
install these packages sudo apt-get install ros-kinetic-gazebo-ros-pkgs sudo apt-get install ros-kinetic-gazebo-ros-pkgs ros-kinetic-gazebo-ros-control
then update and upgrade your ubuntu sudo apt update sudo apt upgrade
I'm not sure this answer is relevant. Did you mean to post this answer on a different question?
sloretz gravatar imagesloretz ( 2018-11-19 11:56:11 -0600 )edit
Asked: 2017-05-10 06:24:05 -0600
Seen: 5,485 times
Last updated: Oct 06 '18
