Model is valid only if not saved as "model.sdf"!!
asked 2017-05-15 17:34:12 -0500
I am using "gz sdf -p <file>" (or with "-k") to check the validity of a model. I was always getting errors, even when I removed pretty much everything from my model. I ended up with just the following, but still without a successful validation:
<?xml version='1.0' ?>
<sdf version='1.6'>
  <model name='forklift'>
    <!-- Base/Support link -->
    <link name='base_link'>
      <pose>0 0 0 0 0 0</pose>
        <pose>0.237624 0 0.122112 0 0 0</pose>
      <collision name='base_link_collision'>
        <pose>0.24 0 0.123333 0 0 0</pose>
            <size>0.06 0.2 0.06</size>
      <visual name='base_link_visual'>
The strange thing is, if I save this as anything but "model.sdf", it says it is valid. If I save it as "model.sdf", it says it has errors (although they do not include any relevante information, as stated in ).
Any ideia why is this?
humm... I saved your example as model.sdf and it checked fine...
chapulina gravatar imagechapulina ( 2017-05-15 17:57:17 -0500 )edit
It seems to me that when I write "model.sdf" it uses another (maybe somewhere in the path) model. If I input the full path into the command line, it parses OK.
Hugo Costelha gravatar imageHugo Costelha ( 2017-05-15 18:22:24 -0500 )edit
