A simple question on changing bounce properties
asked 2017-05-16 03:33:29 -0500
Michael gravatar image
updated 2017-05-16 09:01:03 -0500
sloretz gravatar image
Hello everyone,
I'm trying to model a cube and a slope. The cube free fall under gravity and make collision with the slope. I'm curious about their bounce properties. I try to set the kp in <ode> and restitution_coefficient in <bounce> in my SDF code.
I'm running Gazebo 7 on Ubuntu 14.04.
1.Restitution_coefficient should be the only factor that affects the collision effect, but when I change the value of kp, the collision effect is also affected. Why?
2.When I set the value of restitution_coefficient equal to zero, the cube still bounces from the slope. According to common sense, the cube should be rest on the slope. Why bounce?
The cube SDF:
<?xml version="1.0" ?>
<sdf version="1.5">
<model name="elasticBall">
<pose>0.5 0 0 0 -0.7854 0</pose>
        <size>0.3 0.3 0.3</size>
    <surface>
       <friction>
        <ode>
          <mu>10</mu>
          <mu2>10</mu2>
        </ode>
      </friction>
      <bounce>
        <restitution_coefficient>0.0</restitution_coefficient>
        <threshold>0.01</threshold>
      </bounce>
      <contact>
        <ode>
          <kp>1e10</kp>
          <max_vel>1e10</max_vel>
          <min_depth>0.001</min_depth>
        </ode>
      </contact>
    </surface>
    <mass>2</mass>
      <ixx>1</ixx>
      <iyy>1</iyy>
      <izz>1</izz>
      <script>
      <name>Gazebo/WoodPallet</name>
      </script>
</model> </sdf>
The Slope SDF
<?xml version="1.0"?>
<sdf version="1.4">
  <model name="slopePlaneLong">
    <pose>0.5 0 0 0 -0.2618 0</pose>
            <size>5 5 .01</size>
        <surface>
          <friction>
            <ode>
              <mu>10</mu>
              <mu2>10</mu2>
            </ode>
          </friction>
          <bounce>
          </bounce>
          <contact>
            <ode>
              <kp>1e10</kp>
            </ode>
          </contact>
        </surface>
        <cast_shadows>false</cast_shadows>
          <script>
            <name>Gazebo/Orange</name>
          </script>
The launch file
<launch>
<!-- these are the arguments you can pass this launch file, for example paused:=true -->
<arg name="use_sim_time" default="true"/>
<arg name="headless" default="false"/>
<arg name="debug" default="false"/>
<arg name="paused" default="true"/>
<!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
<arg name="world_name" value="$(find collision_gazebo)/worlds/blank.world"/>
<arg name="debug" value="$(arg debug)" />
<arg name="gui" value="$(arg gui)" />
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="headless" value="$(arg headless)"/>
<node name="spawn_slopePlane" pkg="gazebo_ros" type="spawn_model" args="-file $(find collision_description)/sdf/slopePlane.sdf -sdf -x 0.6 -z 0.6  -model slopePlane" />
<node name="spawn_Cube" pkg="gazebo_ros" type="spawn_model" args="-file $(find ...
(more)
I'm worried about similar problem. Could you resolve this problem? If so, would you tell me the solution of this problem?
Viper gravatar imageViper ( 2017-11-24 03:05:45 -0500 )edit
