How to get laser data from gazebo?
asked 2017-05-19 05:09:20 -0600
lory18 gravatar image
updated 2017-05-19 08:52:32 -0600
sloretz gravatar image
I have modeled a robot with a laser sensor. Whenever it sees anything it range I want to set some force to a joint. I don't understand how to get the laser data via gazebo.
Any help will be appreciated
What version of gazebo are you using?
sloretz gravatar imagesloretz ( 2017-05-19 14:55:25 -0600 )edit
i'm using gazebo ver 7
lory18 gravatar imagelory18 ( 2017-05-19 16:24:25 -0600 )edit
answered 2017-05-22 09:31:19 -0600
There are a couple ways to get the laser data. These work for both the Gpu based ray sensor and CPU based ray sensor, but I'll assume the former. If you're using the CPU based sensor just remove Gpu from everything.
OR
The laser data topic uses publishes a protobuf message every time the sensor makes a measurement. The message definition is LaserScanStamped which is a time stamped LaserScan message. You can see how it gets populated here.
This tutorial shows how you implement a plugin. You'll want to implementing a sensor plugin and inherit from GpuRayPlugin. Specifically your code will go in OnNewLaserFrame
Thanks for the answer, i was missing the part of extrapolating data from msgs, after reading the code it's more clear!
lory18 gravatar imagelory18 ( 2017-05-22 13:31:59 -0600 )edit
2 followers
Asked: 2017-05-19 05:09:20 -0600
Seen: 348 times
Last updated: May 22 '17
