Subscriber with member callback function
asked 2017-05-19 08:56:13 -0500
jelavice gravatar image
updated 2017-05-19 10:22:40 -0500
I am trying to subscribe to the model msgs in gazebo, however I cannot bind the callback function in a correct way. This is the code:
class WorldInterface : public WorldPlugin
public:
    void messageReceived1(const msgs::Model& _msg)
        std::cout << "Got the message!" << std::endl;
        modelLoaded_ = true;
    void Load(physics::WorldPtr _parent, sdf::ElementPtr _sdf)
        transport::NodePtr node(new transport::Node());
        node->Init();
        transport::SubscriberPtr modelSub =
                node->Subscribe("~/model/info", std::bind(&gazebo::WorldInterface::messageReceived1, this, _1));
The error I get is:
error: no matching function for call to ‘gazebo::transport::Node::Subscribe(const char [13], std::_Bind_helper<false, void (gazebo::WorldInterface::*)(const gazebo::msgs::Model&), gazebo::WorldInterface*, boost::arg<1>&>::type)’
answered 2017-05-19 10:28:45 -0500
Try changing your subscriber to this:
node->Subscribe("~/model/info", &WorldInterface::messageReceived1, this));
And your callback to this:
void messageReceived1(ConstModelPtr &_msg)
See an example here.
That solved the error, thanks.
jelavice gravatar imagejelavice ( 2017-05-20 08:31:10 -0500 )edit
Btw can you think of any good reason my plugin is not receiving any messages? As far as I understood, there should be a message broadcasted on "~/model/info" topic any time a model is inserted in to a simulation. I insert the model with parent->InsertModelFile() however no message is received + model count in the world stays exactly the same. I am doing this in the Load function for the world plugin.
jelavice gravatar imagejelavice ( 2017-05-20 11:01:54 -0500 )edit
Asked: 2017-05-19 08:56:13 -0500
Seen: 165 times
Last updated: May 19 '17
