Attaching plugin to a model programmatically
asked 2017-05-28 11:25:13 -0600
jelavice gravatar image
Is it possible to attach plugin to a model directly from the code (not in the sdf files or xml files). So I want to add the model programmatically inside the simulation and then attach a model plugin to that model by specifying the path to the plugin library.
Something like:
//load model
worldPtr_->InsertModelFile(modelName);
//get model pointer
modelPtr = getModelPtr();
//attach a plugin to that model
attachPlugin(modelPtr, pluginName)
The code above should be executed inside the world plugin. Is something like that even possible?
answered 2017-05-29 02:19:02 -0600
This can be done by manually calling the function "Create" with prototype static TPtr Create( const std::string & _filename, const std::string & _name). This function is defined in the ModelPlugin.hh header. After that, the "Load" function with prototype void Load(physics::ModelPtr _parent, sdf::ElementPtr /_sdf/) should be called.
This will load the plugin dynamically and register it to the gazebo server.
Asked: 2017-05-28 11:25:13 -0600
Seen: 145 times
Last updated: May 29 '17
