Twisting continuous joint when velocity increases
asked 2017-06-02 07:41:29 -0500
blevesque gravatar image
Hi all, I simulate a robot with two wheels and when target of velocity joint is "too high", joint twists. Here are my joint description :
<joint name="bottom_${side}_engine_to_${side}_wheel" type="continuous">
  <origin xyz="0.0 0.0 ${-BOTTOM_ENGINE_HEIGHT/2.0}" />
  <parent link="bottom_${side}_engine" />
  <child link="${side}_wheel" />
  <axis xyz="0 -1 0" />
  <dynamics damping="0.1" />
  <limit effort="10000000" velocity="100000" />
  <joint_properties damping="0.0" friction="0.0" />
Joint controller :
<transmission name="left_wheel_traction">
  <joint name="bottom_left_engine_to_left_wheel">
  <actuator name="motor4">
  </actuator>
</transmission>
left_wheel_traction_controller:
    type: velocity_controllers/JointVelocityController
    joint: bottom_left_engine_to_left_wheel
    pid: {p: 100.0, i: 0.01, d: 10.0}
Can someone help me ? I don't understand why joint twists, it is only a joint between a motor and a wheel. Thanks for your time
