'math' has not been declared Gazebo 8 Write Plug in Tutorial
asked 2017-06-05 16:32:59 -0600
michael1234 gravatar image
updated 2017-06-06 15:57:55 -0600
I am following this tutorial --> click me <--
I am getting this error:
**error:** 'math' has not been declared
   this->model->SetLinearVel(math::Vector3(.03, 0, 0));
Wasn't math imported with some kind of library in the script?
Full script:
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <stdio.h>
namespace gazebo
  class ModelPush : public ModelPlugin
      this->model = _parent;
      // simulation iteration.
          boost::bind(&ModelPush::OnUpdate, this, _1));
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
      // Apply a small linear velocity to the model.
    // Pointer to the model
  GZ_REGISTER_MODEL_PLUGIN(ModelPush)
What's your Gazebo version?
chapulina gravatar imagechapulina ( 2017-06-05 19:05:53 -0600 )edit
It is Gazebo 8.
michael1234 gravatar imagemichael1234 ( 2017-06-05 19:24:58 -0600 )edit
You can try adding `#include <gazebo math="" math.hh="">` to the top. I believe the tutorial needs to be updated for Gazebo > 7
chapulina gravatar imagechapulina ( 2017-06-06 15:30:11 -0600 )edit
It didn't work for me.
michael1234 gravatar imagemichael1234 ( 2017-06-06 15:58:12 -0600 )edit
answered 2017-06-06 16:01:07 -0600
The Gazebo documentation isn't updated, I had to used the ignition library.
ignition::math::Vector3<double /* var type */ >(0.03f, 0.0f, 0.0f);
answered 2017-06-06 15:59:13 -0600
That tutorial probably needs to be updated for Gazebo 8. It should be changed to use ignition::math instead of Gazebo math.
You can try the following:
  1. Include ignition math vector:
    #include <ignition/math/Vector3.hh>
  2. Change math::Vector3 to ignition::math::Vector3d
The include isn't necessary.
michael1234 gravatar imagemichael1234 ( 2017-06-06 16:04:26 -0600 )edit
Asked: 2017-06-05 16:32:59 -0600
Seen: 2,735 times
Last updated: Jun 06 '17
