Robot tilting problem on linear acceleration
asked 2017-06-26 07:50:37 -0600
SorinV gravatar image
updated 2017-06-28 08:45:05 -0600
Hello, I am trying to simulate someting close to the Nexus 3-wheeled platform.
When I accelerate with 2 wheels in the direction of the third, the latter wheel gets raised into the air. I used the fomulas on wikipedia to calculate my inertia. For the mass I tried with 10, 100, 200 kg with the same tilting result.
I mananged to set the friction directly in the .sdf file generated from my urdf.
<friction>
  <ode>
    <mu>0.9</mu>
    <mu2>0.001</mu2>
    <fdir1>0 1.0 0</fdir1>
  </ode>
</friction>
(I set it directly in the .sdf file because i noticed another problem described here.)
I also setup the joint model stiffness parameters kp, kd like so:
  <contact>
    <ode>
      <kp>1e+08</kp>
      <kd>1</kd>
    </ode>
  </contact>
in order to have some stiff wheels when in contact with the ground plane, otherwise they pass through.
Would I need to setup something else? I am using ros-kinetic and the gazebo delivered with it, Gazebo7. (I use ros_control ( a modified version of diff_drive_controller for the 3-wheeled base) and of course continuous joints)
Tnx and regards!
UPDATE
I also had a small arm on top of my robot, with a really small weight compared to the base but with it's own inertia. I deleted all that and now I just have a base with 3 wheels and it works fine. For now it's ok for what I need but for the future I will need the arm also.
It's the third wheel that raises? How high? What's the acceleration? Do you have a video of the behavior?
sloretz gravatar imagesloretz ( 2017-06-27 12:58:17 -0600 )edit
Yes the third wheel (aith the base link too, not just the wheel alone), like it had a huge inertial value on the robot. Not too high because my robot is low so it hits the ground with the back of the base_link. I made an update in my question.
SorinV gravatar imageSorinV ( 2017-06-28 08:42:46 -0600 )edit
answered 2017-07-31 07:14:22 -0600
updated 2017-07-31 07:15:06 -0600
So i had this problem because of a prismatic joint I was using:
I managed to use velocity_controllers/JointPositionController instead of position_controllers/JointPositionController with the prismatic joint. You just need to add a PID for it. Here's an example.
Before:
arm_controller:
  type: "position_controllers/JointPositionController"
  joint: arm_joint
After:
arm_controller:
  type: "velocity_controllers/JointPositionController"
  joint: arm_joint
  pid: {p: 100.0, i: 0.01, d: 1.0}
And for the transmission:
<hardwareInterface>hardware_interface/VelocityJointInterface </hardwareInterface>
Same answer/problem here.
2 followers
Asked: 2017-06-26 07:50:37 -0600
Seen: 294 times
Last updated: Jul 31 '17
